Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 2011 - 2019 Ford Explorer 5th Generation Explorer
- Stock 2011 - 2019 Ford Explorer Discussion
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Explorer 'A' pillar replacement
- Thread starter barnsY90
- Start date
Add an avatar, upload photo attachments, and more!.
ljcorby
- April 11, 2018
- Great Meadows, NJ
- 2013 Ford Explorer XLT
We have a 2013 XLT and the driver side is loose at the top. Where did you purchase your replacement kit(s)?
Ok, I went ahead and took some pics in the process...
My exterior moulding broke a few months ago due to road debris, and the inner moulding took some damage, so I bough the new parts finally to replace them.
SInce I had no exterior moulding, I started by removing the inner moulding...
no big deal...
The new inner moulding with the 7 plastic tabs, and the old one. Notice there is an 8th tab (not shown) that clips on the marked hole. This tab comes attached to the exterior moulding.
The new inner moulding in place...
The new exterior moulding in place, just apply some pressure, so the tabs can clip into the holes.
NOTE: Be careful if you need to remove the exterior moulding, since the tabs can easily break. Start from the top, and work your way down...
- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
Where ever you get it from, make sure that the plastic clips are included. Moldings for 2013 Ford Explorer | Auto Nation Ford White Bear Lake
dont slow down
- December 1, 2014
- Elizabeth City NC
- 2022 Explorer Limited
Read through this thread and am a little confused. Is the top trim reusable? If the mount comes with new clips can I use my old trim piece? The weatherstripping on mine is torn and I’m looking to replace it.
ljcorby
- April 11, 2018
- Great Meadows, NJ
No the top trim is not reusable. It would have to be replaced. It will just fly off again. And like others have said, make sure you replace the clips....very important of your new top trim piece will have wings again. Don't ask me how I know.
13XLTExplorer
- October 17, 2019
'A' PILLAR WINDSHIELD RETAINING STRIP WEATHERSTRIPPING
The weatherstripping/rubber seal that is attached to the A Pillar Windshield Retaining Strip (PN: BB5Z-803145-AA is deteriorating and part of it has torn away and come off. It looks as though this weatherstripping is part of the retaining strip. Can I order the weatherstripping separately? If not, is it a critical piece? Am I in danger of letting water in and damaging the interior and other things? Thank you in advance for your help.
Did anyone ever find out about purchasing JUST the weather stripping???
- December 28, 2010
- Callsign
Welcome to the Forum.
No one has ever just bought the weather stripping that I'm aware of. See post #46. It seems to suggest it is part of the strip as well.
- May 3, 2005
- Litchfield Park, AZ area...
- 2021 King Ranch 4wd 3.0T
I am having to go by my Safelite location as they did the replacement and BOTH A pillar trims are coming loose but are still attached.... for now.
Darren McCoy
- December 6, 2019
- Mahomet
- 2014 Ford Explorer Base
I bought the parts to do this replacement myself, passenger side trim flew off. The replacement parts came with a giant tube of auto glass Urethane Adhesive. Is this to go on the weatherstrip? Anyone have any idea how much to use and where I should apply it? thanks in advance.
- December 28, 2010
- Callsign
Welcome to the Forum Darren.I bought the parts to do this replacement myself, passenger side trim flew off. The replacement parts came with a giant tube of auto glass Urethane Adhesive. Is this to go on the weatherstrip? Anyone have any idea how much to use and where I should apply it? thanks in advance.
Did you get the package from Ford? I'm asking because no one that has done the DIY ever mentioned getting a tube of adhesive.
Darren McCoy
- December 6, 2019
- Mahomet
no they are not Ford oem.
1st time Ford
- November 20, 2019
- 2017 Explorer Platinum
My 2017 Sport were both cracked upon delivery. Arnold the body builder must have been the guy installing them that day. Both were cracked at the top and both had some factory glue added for adhesion. I think they are one of the most complicated over engineered trim pieces I have ever encountered. Not to worry, the drivers door pillar/keypad just started flapping in the air at 13k miles. Warranty covered but I just found a flat 2'' x 3'' piece of trim that is some kind of cover piece in the back seat after bringing home some of my daughters soccer team. I have not found where in the heck it goes yet!? The numbers on piece are 2449581 L >PP< and I am actually a pretty good car mechanic, but a bit embarrassed on this one.
Hi CAtoFLin1994, did you ever find out what that part was (2449581 L >pp<? I just found one exactly as you described on the middle seat of our 2017 Explorer Platinum. I looked everywhere around where I found it (even flipped the 2nd row seats forward). Yet everything looks normal. Worth mentioning, in case the dealership broke something else, we just got it back from the Ford Dealer who replaced the second row middle seat seatbelt and also had to replace some bracket underneath the third row seats (they would not stow flat and usually got stuck in a partly folded position). Fortunately, all was covered under the 3-year / 36,000 mile bumper to bumper warranty. But now I found that "mystery part". Thanks for any help you might be able to offer.
1st time Ford
- November 20, 2019
I found it! The mystery trim piece that was referred to above (with part # 2449581 L >pp<) belongs on the left side of the center fold down armrest, near its hinge point (this is on a 2nd row, split bench seat). It is used to cover the two torx head bolts that appear to be holding the armrest to the hinge.
Tom shaw
- July 18, 2016
- Batesville, ar
- 2020 explorer limited
Welcome to the forum barnsY90.
1. It's called the passenger side "A" pillar cover.
2. It would be best to take it to a dealer and let them fix it. Another good place would be a glass shop that knows what they are doing with windshields.
The plastic clips that hold this part down are known to break easily and cause noise. Some have even flown off in traffic.
Good Luck!
Tom shaw
- July 18, 2016
- Batesville, ar
On my 2017 the a pillar trim flew off driving down the road of corse it’s not covered by the extended warranty. Why does an expensive car have cheap trim. Sounds like a recall to meOn the passenger side, the black plastic cover on the top is no longer latched. I can see that the plastic mounting piece has split. What's this thing called (or part number) and where's the best place online to buy it?
Thanks for your help.
- December 28, 2010
- Callsign
No recall will be forthcoming. Recalls are issued for 'Safety' realted items. This has been going on since the 5th gen was introduced 10 years ago.On my 2017 the a pillar trim flew off driving down the road of corse it’s not covered by the extended warranty. Why does an expensive car have cheap trim. Sounds like a recall to me
meisterhyde
- February 4, 2015
- Lansing, MI
- 2014 Explorer XLT AWD
Any luck with Safelite? I too had my '14 explorer windshield replaced a year or so ago by them. Passenger side A Pillar trim/cover just flew off on our way from central Michigan to Indianapolis. I had no idea these were an issue and that Safelite should have included new in the replacement.
- December 28, 2010
- Callsign
The issue is with the plastic clips. If they tried to reuse the old ones, chances are that some of them may have broken. This was a problem with the early models and then Ford began including all new clips with the pillar replacements.
Schrader
- May 4, 2019
- Vicksburg,MS
- 2016 Explorer Sport
I had a problem with the top end of driver side top trim trying to come loose and was sticking up about 3/4 from the roofline
I got to studying it and my research indicated that the whole assembly (top and bottom) is supposed to be a one use application.
When I lifted the top corner a little bit more, I noticed a couple of flat plastic surfaces sticking up from the bottom piece that would probably hold some adhesive of some sort, and if I applied adhesive to the flat pieces and taped the top piece down, it may just hold when the adhesive cured.
So I put just a dab of pl premium between the top and bottom pieces and taped it down tight with blue painters tape.
I let it cure for 24 hours and when took the tape off.. and bickety bam, the top corner is now back down flush with the roofline.
Cheap fix to delay the inevitable replacement of the whole assembly when my windshield gets cracked.
- May 3, 2005
Yes, they came out and replaced both trim pieces AND GLUED them in place due to the installers experience in having issued with the "locking tabs" not locking long term.
Similar threads
- Replies
- 1,416
- Views
- 460,926
- Replies
- 68
- Views
- 15,083
- Replies
- 6
- Views
- 7,274
- Replies
- 1
- Views
- 266
- Replies
- 8
- Views
- 8,977
