Explorer Navigation Tracking Problem
minne
Minneapolis, MN
2014 Ford Explorer Sport
update after TSB
Hi everyone, I've been pretty quiet here but have an update for you on my '14 Sport nav issues that started upon the install of 245/60R18 Blizzak DM-V1 winter tires. I had TSB 14-0037 done 3 days ago, while the snows were still on, and the results were very good. The nav after being "off the mark" since the winter tire install, was spot on....no matter if I was in the country or in the city, it held true to my actual position, and stayed spot on for 3 days (hooray, no more driving across lakes, rivers and fields!) I just swapped out the snows for the 20" Hankook's and can say that the nav remains spot on. I will be watching it closely over the next few days, but thus far the TSB seems like it took care of things.
AdamLewis
2014 Ford Explorer XLT
I contacted my Ford dealership that I bought the car from and they said that there are no TSB's out on my vehicle and everything is up to date. The TSB 14-0037 looks like its for vehicles built before January of 2014. Mine was built in March but is having the exact same symptoms. They suggested I unhook the battery for 20+ minutes to do a master reset on the electronics. Anyone else still having issues? Any suggestions on what else I can do? The navigation is all but worthless without this fixed. It puts me 50+ yards off the road I am on so when it gets to a side road it recalculates route and cant get me back on track. Very frustrating for a brand new car to have. Google maps by far is better.
R56 Ed
AA Co. Marylandistan
2014 Explorer XLT
Try disconnecting your battery overnight... it worked for me (none of the other 'fixes' helped). Good luck!
Raafter68
2014 Explorer Sport
**Final Update**
Since the summer tires went on the navigation tracking has been perfect. We've driving from Ontario to Myrtle Beach 1200-ish miles and it's been perfect every step of the way.
It will be interesting to see once we put the winters back on.
**UPDATE**
I brought the Sport into the dealer 12-13 days ago. We switched out the winter tires to summers & I had them check the navigation issue. They advised the TSB didn't apply to us because our system was up to date with everything. This didn't make sense to me because we've had it since mid-December. They also said they didn't "do" anything other then check the build.
All I know is the system had definitely been worked on or reset because all the setting were changed. Breadcrumbs were turned on, lots of differences to the settings we'd had.
With some scepticism, I asked the next steps for replacing the module because I was sure the tracking issue would be back by the time I made it home. The service manager said there was no specific protocol however it would take time to convince Ford to go to that expense. I pushed & he mentioned logging the issue with Ford would be a good thing to do.
I let him know I was going to go hard after this because were heading on a family vacation at the end of April & I wasn't leaving without the issue fixed. His suggestion was to use my Harley GPS as a backup.
I let him know we didn't spend tens of thousands of dollars on a new vehicle to need to use a portable GPS.
He was quite pleasant the whole time.
Expecting the worst, I left & for the least two weeks the tracking has been dead on 100% of the time.
My conclusion, I haven't got a clue...
Winters off, summers on, possible system reprogramming(???), possibly just reset.
Happy its working though.
Best of luck to everyone else.
AdamLewis
Disconnect Battery for Navigation fix...
I disconnected the battery overnight last night. Once reconnected, at first I didn't think it had worked because all my radio stations, MFT background, and other settings hadn't changed. Thought disconnecting the battery overnight would have reset all these settings. At any rate, I set my navigation to my office as I've done over the past couple days to check it out and see if it would do the same thing. When I got to the locations that had been putting me off by 50 to 60 yards on the side of the road the nav kept me right on track today. I'll be monitoring it more over the next few weeks. ***I did not have winter tires removed and summer tires put on. I simply disconnected the battery overnight***. Keeping my fingers crossed! So far it seems to be fixed. The one thing I'm still not 100% pleased about is that it constantly tries to recalculate to a better route when I know for a fact that the one I'm on is the best one. Google's maps match up to what I know to be better. Wonder why their so different? Obviously algorithms are different but the navigation is trying to take me off of the main highway onto side streets. I've tried each of the settings in route settings and nothing seemed to changed. Oh well, I can live with that. Thanks for the help/suggestion.
LukerDooker
N.E.
2013Limited 301A TuxBlack
In the route choices, if its Shortest or Fastest, it may still do as you described, although in my area hiway is usually fastest', local is shortest, as the hiway cuts around everything.
Leaving mine on fastest' has let it go hiway as much as possible and no
avoids' are turned on. Works well.
When the GPS took me along a hiway and then local, cutting across the hiway, then back to hiway - it stunk.
But it was shortest'...
It will also keep prompting and recalc as you pass by any street after deviating from the GPS route to get to a point you know is faster or easier.
Essentially if you have no clue and are in a new area, it will get you there but
if it goes local on a trip you know has more hiway, its a drag.
Try fastest' and no avoids.
Besides a 2nd GPS on a phone is reviewing the route before leaving, and you can edit the turns shown in the route.
That sometimes will allow you to remove excessive local exits that only take you off the hiway and back on it later.
AdamLewis
Thanks. Will try fastest with no avoids. I'll try playing around with the settings more and try different variations.
MikeDU
2011 Ford Explorer LTD
Navigation system in 2011 Ford Explorer faulty.
The navigation system in my 2011 Explorer does not work very well. The system usually displays the 'GPS' icon with an 'X' through it, and the location displayed on the map can be blocks away from where it should be. On the rare occasions when the icon does display without the 'X' through it the location shown is usually correct. This problem appears to be worse ever since the latest software was installed.
It almost seems as if there is a problem with the system (the antenna?) not picking up the signals from the satellites. Has anyone else had a similar problem which has been definitely shown to be an antenna problem?
It's interesting that my Android tablet computer (about $200) onto which I've downloaded free GPS navigation software has absolutely no problem working in the Explorer. Seems to me that Ford has a real problem with their overpriced GPS system, but they will, of course, not admit it!
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
It's not unusual for it to be off track if there isn't a signal being received (red X). For your info, the GPS receiver is under the dash.
vfral1
Cumming, GA
'11 LTD Golden Bronze
I would estimate that 80% of the time I have been in the ex, the red x was displayed. Yet much of that time the gps does appear to function. I have gone into diagnostic mode and best I can guess is when you see 4 or less satellites, you get a red x.
I have a hand held garmin that locates 8-9 satellites in the same location that the ex finds 3-4. I truly believe this is the root of the problem with the gps that some of us experience. Ford should fess up and replace the hardware that runs this system. I'm not asking for anything more than what I paid for.
MikeDU
"It's not unusual for it to be off track if there isn't a signal being received (red X). For your info, the GPS receiver is under the dash.
Peter"
Thanks, Peter, for your comment. I do appreciate that the system can't work if it doesn't receive a signal from the satellites. (I've worked with hi-tech electronic equipment all my working life.) My problem is understanding why Ford's expensive system doesn't have an antenna that can pick up the satellite signals at least as well as my relatively cheap 'tablet'. The more I think about the problem, the more convinced I am that the primary cause of the problem lies with either the design or the location of the antenna.
peterk9
Staff member
Moderator
Callsign
VE3
Peter"
With the antenna being under the dash, I'm sure there would be more likelihood of some kind of interference from other objects compared to an item that is out in the open. Have you tried disconnecting the battery for an extended period of time? This seems to have helped a number of members in getting the Nav back on track.
vfral1
Cumming, GA
I do appreciate you trying to help, but honestly having to disconnect the battery to make something work is a failure of engineering in my book.
AND it does not work anyway; my battery died three weeks ago and so it had to be disconnected and removed. Driving away from the sears I still had the red x and 500 yds off course displayed by the nav.
lazychuck49
2012 Explorer
Similar Garmin Results??
fyi, have heard from cyclists that when biking around large bodies of water that their garmin gps's will sometimes show them way off the route. i've seen the garmin results myself and they look very similar to what i see in my explorer gps.
note when biking in a city with tall buildings the garmin route is often off. they guess that it's likely due to gps signals getting reflected off the buildings. they also wonder if the signals get bounced off the water, scrambling their route a bitl.
fordlimited
2014 Ford ExplorerLimited
Any fix yet? I have bought a 2014 Ford Explorer Limited. I just drove to Chicago and found GPS is showing my car at off road position. It always showing a distance between my car and the actual road. I have rebooted the MY ford touch and also updated with latest software Gen2 - V3.6.2, but still no luck. Why Ford does not show a simple interest to fix this issue?
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum fordlimited.:wavey:
Since your position seems to remain consistant I assume that you don't have the GPS with the red X showing. Have you tried just removing the S/D card and reinserting it? I would think that this is a navigation issue and not an MFT one.
You can try sending a private message to Rebecca (FordIVTteam) to see if there is anything she can do to help. You can use this link;
http://www.explorerforum.com/forums/private.php?do=newpm&u=181992
When you PM, be sure to include your full name, best daytime phone number, VIN, mileage, and servicing dealership in your message.
fordlimited
Thanks Peter to show me the right direction. I appreciate. I hope Ford do take some initiative to resolve these issues.
65Steve
Baiting Hollow, Long Island, New York
2011 Explorer
I had the same issues with my '11 Explorer until I took it to another Ford dealer a few months ago. My dealer worked with Ford IVT and they discovered that 2 modules that work with the GPS mod had different issues of programs in them. They ended up wiping out the programming in all 3 mods and reinstalling the latest ones available. Since then the nav system is about 98% reliable. It still gets 'lost' once in a while, but usually corrects itself within 2-4 minutes. It is a vast improvement over what I experienced since the Exp was new. Best part? Even though my Exp was way out of warrantee (60K miles), Ford covered the entire cost.
A Aftermarket 12.1" Android Navigation Radio for Explorer 2011-2016 My Ford Touch / In Vehicle Technology 4
K Another Explorer Navigation Error 2011-2016 My Ford Touch / In Vehicle Technology 9
S Does Explorer 2012 XLT have Navigation? 2011-2016 My Ford Touch / In Vehicle Technology 5
B Navigation for Explorer 2013 XLT 2011-2016 My Ford Touch / In Vehicle Technology 15
R POI problem with Explorer's navigation system 2011-2016 My Ford Touch / In Vehicle Technology 13
F 2014 explorer xlt 4wd No"traction ctrl"option in "Driver Assist" 2011-2016 My Ford Touch / In Vehicle Technology 2
D 2014 Explorer Limited Cannot use both USB ports at the same time 2011-2016 My Ford Touch / In Vehicle Technology 5
C 2013 Explorer Rearview Camera Issue 2011-2016 My Ford Touch / In Vehicle Technology 3
S Adding One Touch to rear windows 2018 Explorer Sport? 2011-2016 My Ford Touch / In Vehicle Technology 5
J 2013 Ford Explorer XLT - Controls not working 2011-2016 My Ford Touch / In Vehicle Technology 9
M 2016 Explorer Limited - Front USB ports not working 2011-2016 My Ford Touch / In Vehicle Technology 13
P 2011 Explorer XLT APIM issues 2011-2016 My Ford Touch / In Vehicle Technology 1
iTonyp Sync 3 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 2
E 911 Assist Fault Explorer 2013 2011-2016 My Ford Touch / In Vehicle Technology 12
N 2016 Explorer Sport Front Camera Doesn't Work 2011-2016 My Ford Touch / In Vehicle Technology 1
D 2011 Ford Explorer Sync 2 replacement 2011-2016 My Ford Touch / In Vehicle Technology 2
R 2013 Explorer Sport Cruise Control 2011-2016 My Ford Touch / In Vehicle Technology 21
S 2012 explorer cross traffic fault blind spot fault 2011-2016 My Ford Touch / In Vehicle Technology 1
J 2015 Explorer Sport - upgrading Sync 2 to Sync 3 - have few ?'s 2011-2016 My Ford Touch / In Vehicle Technology 15
M 2013 Explorer - Left Information Display - White with black lines 2011-2016 My Ford Touch / In Vehicle Technology 15
S Issue with 2015 Ford Explorer Key Fob 2011-2016 My Ford Touch / In Vehicle Technology 3
N 2012 Explorer XLT Keyless Entry Inoperable 2011-2016 My Ford Touch / In Vehicle Technology 4
W 2011 Explorer XLT - Radio Problems 2011-2016 My Ford Touch / In Vehicle Technology 2
J 2013 Ford Explorer message 2011-2016 My Ford Touch / In Vehicle Technology 8
P Upgrading 2016 Explorer to Sync 3 - FORScan questions 2011-2016 My Ford Touch / In Vehicle Technology 28
G Software updates for 2014 Explorer XLT 2011-2016 My Ford Touch / In Vehicle Technology 1
A 2011 Explorer APIM Question 2011-2016 My Ford Touch / In Vehicle Technology 3
F 2013 Explorer Media Interface Question. 2011-2016 My Ford Touch / In Vehicle Technology 5
K Newbie to the Explorer forum question 2011-2016 My Ford Touch / In Vehicle Technology 8
K 2013 Ford Explorer 200 Plug In Play Remote Start Key Fob not working 2011-2016 My Ford Touch / In Vehicle Technology 4
W 2017 Explorer D.I.Y. Remote Start.. 2011-2016 My Ford Touch / In Vehicle Technology 18
J Issue with Sync in 2011 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 14
A Radio wiring diagram for a 2013 Explorer XLT 2011-2016 My Ford Touch / In Vehicle Technology 14
S Add (after market) Collision Avoidance to 2015 Explorer Sport 2011-2016 My Ford Touch / In Vehicle Technology 3
G Android screens for ford explorer 2011-2015 2011-2016 My Ford Touch / In Vehicle Technology 3
G Ford Explorer 2015 XLT additional key 2011-2016 My Ford Touch / In Vehicle Technology 2
L 2013 ford explorer sport headrest DVD. HELP! 2011-2016 My Ford Touch / In Vehicle Technology 2
G Installing Backup Camera and 8" Screen in my 2013 Explorer - Is it possible? 2011-2016 My Ford Touch / In Vehicle Technology 3
H Location of 2013 Explorer Service Button 2011-2016 My Ford Touch / In Vehicle Technology 14
J SYNC 3 in a 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 259
J Siri and XM Radio Questions - New 16 Explorer Platinum 2011-2016 My Ford Touch / In Vehicle Technology 8
M 2012 Explorer USB Ports 2011-2016 My Ford Touch / In Vehicle Technology 1
G Buying a 2012 Explorer - Nervous about MFT Issues (please advise) 2011-2016 My Ford Touch / In Vehicle Technology 7
R 2011 Explorer XLT alarm issue 2011-2016 My Ford Touch / In Vehicle Technology 0
D 2015 Explorer Sport - Intermittant no-start with push button start 2011-2016 My Ford Touch / In Vehicle Technology 21
S Installing a Blackvue in a 2016 Explorer 2011-2016 My Ford Touch / In Vehicle Technology 9
P 2016 Ford Explorer and Remote Climate Control 2011-2016 My Ford Touch / In Vehicle Technology 2
J 2016 Explorer with MFT - Add Climate Control to Instrument Cluster 2011-2016 My Ford Touch / In Vehicle Technology 25
J Add HD Radio to your Explorer 2011-2016 My Ford Touch / In Vehicle Technology 1
M 2013 Explorer Security & Remote Starter Options 2011-2016 My Ford Touch / In Vehicle Technology 16
Similar threads
