extreme body sway after lift | Ford Explorer Forums
eric©
Detroit, MI (yeppers, redneck white boy invading D-town! :-P)
1991 XLT 4x4
Finished the lift on my X over the weekend, now I have MASSIVE body sway at any speed above 45mph, to the point of the truck feeling like its very close to losing control and flipping over. I have no clue what the manufacturer of the front lift is, it's 4" coils, and drop bracket for the passenger beam, drop plates for the driver's beam and RA mounts. Drop pitman arm. I did a SOA in the rear. Stock shocks mounted below axle (reversed shock mounts). I yanked sway bars front and rear (always have run sans sway bars on all my 4x4s, I'm quite used to driving without them). I know the front alignment is still a bit out of whack from the lift (planning on installing spacers this weekend to level the truck, then get it aligned).
Does the lack of a sway bar on the TTB suspension really make for an unstable truck? My alignment is a bit on the toe out side, but seems to drive OK. It drives fine at slow speeds, but once i'm up to 35+, I hit a bump, body sways to one side, back to the other, back to the first, etc. Getting worse and worse until I slow down. It's doing the same thing as if I was sawing the steering wheel back and forth, only a LOT worse. It reminds me a lot of the death wobble that Jeeps get, only in the body instead of the steering wheel.
Yeah the sway bars really do help.
I just drive slower and make sure if I'm going out of town that I trailer it.
Jeff - :navajo:
You sure everything is tightened up and the RA bushings are in correctly? The rear shocks may have something to do with it (or the angle they're mounted at), but I know a bunch of people that run like you do without problems. Heavier shocks and a steering stabilizer might help too.
Jeff - :navajo:
Wonderful idea, except this is my daily driver, and I have no other vehicles at the moment. It also is completely unusable on the freeway. Considering I have a rather long commute to work, this is getting real old real quick :(
Everything was run down with an impact. Orginally, I did it with the truck in the air, and was told that I should have put weight on the rear end, THEN tightened the shackles just snug. I loosened the bolts on the ground, and then snugged them up. Helped a lot, but didn't eliminate the problem. I'm wondering if I should have done that with the front pivots as well.
I never removed the radius arms during the lift, just the brackets from the frame. The rear shocks are still mounted in factory locations, I just swapped the mount plates side to side, and bolted them back up under the axle.
Why not put the sway bars back on, and see how it drives? Or just one. That might control it enough. Just take them off for wheeling.
cause I don't have extended links for the sway bars, and don't really wanna dump the cash into them only to find out I have the same problem. I used to run quick disconnects on my Jeep, and found it to be a real PITA to try to connect them back up when the Jeep is covered in mud from a day's wheeling, and I'm laying in a muddy parking lot.
I can get mine back on no problem, with a 4" lift.
I know you don't want to have sway bars, and I totally understand. But if it's your daily driver and only vehicle, you gotta do what it takes to get to work and back without :roll:.
When i first lifted mine it did that when i had no sway bars. Now im running a sway bar and RS9000 shocks all the way stiff. It makes a huge difference!
just throw the front sway bar back on there.... you can just take one side loose for wheeling and it wont limit your travel.
I will sell you my 4" superlift extended links for the rear.. Its off of a second gen, but they should be the same. I dont really need them, let me know.
The second gen links are different than the first. DEFINITELY use the sway bars. I drove without mine and hated the looseness, even without the rear I could feel an unstableness.
EDIT: Actually the rear links may be the same ;)
