james t said:Y2K F150 rear rotor. Cheap and should slide right on.
If it doesnt fit perfect, you can always grind down the outside of the axle flange. 9" guys have been doing this on disc swaps for a long time. One of the more popular 9" discs is to use CJ7 front rotors and turn down the flange on the axle. You can do it however is easiest to you... i used a grinder.
Stic-o said:Dosn't anyone do custom rotors? I just need a Exporer rotor with a bigger hub center and 5 on 5.5 pattern. how hard is that![]()
Michael said:Any machine shop should be able to do that for you. Take them an off the shelf rotor and give them a new center hole measurement. The bolt pattern redrill is simple as well.
Between the height, and the fact that that rotor is vented so it will be thicker than the stock explorer rotor will be a problem I imagine.Stic-o said:Ok looks like I may have a good solution.
Looks like I may be able to use a 92 Suzuki Sidekick 4dr front brake rotor. they ar as close as I can find so far.
Explorer
5x4.5 lug pattern
small hub
outside dia 11 7/32 (.2185)
height 2.29
Sidekick
5x5.5 lug pattern![]()
larger hub![]()
outside dia. 11 19/64 (.2968)
height 1.815
The only thing that may hurt me is the height![]()
but they are pretty dam close
Zuk rotor
Jefe said:Between the height, and the fact that that rotor is vented so it will be thicker than the stock explorer rotor will be a problem I imagine.
Why not just rework your stock rotors? I know it will work with a 5x5.5 bolt pattern as many jeeps upgrade to the 8.8 w/ discs. Johns disc brake kit even came with explorer rotors that were drilled for both 5x4.5 and 5x5.5.
You also have to deal with parking brake somehow. the explorer has the parking brake drum in the center of the rotor.
EDIT: all the explorer disc brake stuff just bolts to the axle tube flange so it should swap over unless the axle has to change length to do so? If so I'd rather pay the $250 for custom alloy axles rather than a custom brake kit.
Stic-o said:by the way Jefe I talked to your rear end guy. $125 now per axle![]()
gijoecam said:I'm still a bit confused.... If'n you're using the F-150 rear axle, why not use the F-150 discs? If anything, I'd have a set of custom axle shafts built to whatever lug specs you want (like if you wanted to match the front set) and then you could run the same bolt pattern front and rear, no?
Not sure how it would work out cost-wise though....
-Joe
