KKM from Kurtz Kustoms
K&N = WAY overpriced.
The key to a cold air intake is the cold air feed, alot of people install a K&N and call it good, well the stock airbox is better then that because it feeds the filter cool air from behind the grill.
Also to take advantage of a KKM style intake you will want to eliminate the restrictions installed from the factory in your stock intake, they are:
Stock intake duct to the airbox (very restrictive)
air silencer or muffler (above radiator, also resrtictive)
paper filter (very restrictive)
thats just an intro for you, there are many many things to consider, the basic rule is as follows:
1. Think of your engine as an air pump, the more air you pump the more power you will make.
2. You are only as good as your smallest bottleneck, so opening the intake up for free flow and not doing anything to the exhaust wont gain you anything.
When you get to the very high elevations your stock intake restrictions will become very obvious as it tries to suck oxygen and cant get enough.
I would pass people at the top of Eisenhouer pass with a pretty much stock BII, even V8 powered Explorer's and the like, because I had 0 restrictions on my intake
