Mberry0614
- October 28, 2021
- Festus, Missouri
- 99 Explorer EB 4.0 SOHC
99 explorer 4.0, 4x4 - 190xxx, My OD light has been flashing intermittently. It started off only doing it every once in awhile, but now it seems to be doing it more frequently. When the light is flashing, there is some hesitation on acceleration like the brakes are dragging, it tends to stall when shifting, and there is occasionally grinding noise when applying the brakes, Occasionally, the 4wd lights will also flash, and every once in awhile it sounds like something is binding up when turning the wheels. I checked fluid and it looks fine, doesn't look burnt or anything. I'm hoping maybe a fluid & filter change might do the trick? Maybe trans speed sensor or one of the differentials or hub? Any ideas?
