ExplorerXLT95
- August 1, 2005
- Annapolis, MD
- '00 XLT 4.0 SOHC
Finished the modification this afternoon so here are the pictures. First the relay box with the top off and relay spot 1 empty.
Here is the stuff that you will need to make the jumper.
And finally here is the jumper installed.
A better way to do this would be to "find" an old relay someplace and then just cut off the two small outside blades. That would take away the power from the relay so it wouldn't energize to turn off the fog lights and would still look like a stock setup. I may have to look for a relay the next time I'm at the junkyard.![]()
So, does making this jumper require soldering wire? I really hope not because I am NOT good at it...
