I'll second that.. Be real niceOriginally posted by Mike 92 XLT
What I would like is an adapter to bolt the AOD up to the 4.0.
peace
Mike
Originally posted by Rick
I have heard that a C-4 will bolt up to a 4.0? Do you know what the C-4 would have to come out of to match the bellhousing pattern?
According to your signature you have a 302? If that be the case why do you need an adapter? A c4 bolts right up to a 302.....Originally posted by LOGJOCKY
If it gets made I will buy it for sure. C-4 or AOD would be great!
Originally posted by Diff Whack Daddy
When replacing the A4LD with the C4/C5 combo, how does it effect the bolting up of the BW 15-54 t-case. I know they have a wierd 5 bolt pattern as opposed to the standard 6 bolt circle that the AOD probably has. If it is a 6 bolt circle pattern on the AOD you could always run a different t-case with a Saturn overdrive in it to regain the lost overdrive.
I would like to see a specific details and parts to make something like this work.
