turtlecruise
- October 29, 2007
- conway nh
- 2000 explorer sohc 4wd
2000 Explorer 4.0 SOHC 4x4 Auto. Need the set of three bolts/nuts that mount the front differential to the frame.
I believe they are all the same from 1998 to 2001, and some SportTrac also fit. Email is sdwakaturtle and I
am at hotmail. Thanks. Mine are rusted out & be be destroyed when I lower the diff to replace motor mounts.
Grade is 10.9 on the bolts. Nuts have a metal tab/flag to stop it from rotating so you need only turn the bolt head
to remove.
to remove.
