EMG7895
- November 7, 2003
- '91 xlt, 93
99 mountaineer 302, awd, 125k on the clock. I've been getting a lot of clunks in the front end for about a year now and have gone through just about everything and theres still something not quite right. So far I have replaced both upper control arms (switched to a one piece on the passenger side), both lower ball joints, both tie rod ends, both sway bar links and bushings. All of that has been moog parts so it should be good for a while. I also put 2 new timken hubs on it, new cv axles, pads, rotors. The only things that leaves is inner tie rods and lower control arm bushings. The problem is a popping or clunking noise at low speeds that happens mostly when coming to a stop or starting off from a stop. The noise seems to be coming from the passenger side and also happens when making sharp low speed turns, but its hard to pinpoint it exactly. I've read about missing bolts/ loose transmission mount causing this noise, but mine appears to be tight although I did order a new mount and will try that soon. Any insight to what could be causing this, could it be the lower control arm bushings, or even the front diff mounts?
edit: forgot to mention that it also has a new oem front driveshaft about 10k ago.
