I purchased some white xexnon bulbs (3157) to replace the amber ones that blink when I turn my signal. First I would like to know how you can make them stop blinking. I am assuming that by cutting one of the three wires would stop it from blinking but I do not which one to cut. Has anyone out there done this? Does is affect the blinking sequence to the other? What I mean does it affect it like when you pull out the bulb completely the blinking sequence is faster than when everything is working and in place.
Also, when I installed the white bulb in the front, just above the headlight it is not as bright. I want it to blend in as close as possible to the headlight. Right now it is a dim white, but when i turn the blinker it gets really bright. Any one know how to brighten the bulb. Hit me back please if anyone has ever done this. It seems to me that the bulb is not as bright as it can be because when it blinks it get really bright
