Walnut777
- February 25, 2008
- South Carolina
- 96 XLT
As most of us know last week I tackled that beast they call a heater core in my 96 explorer. Well, tonight I needed to use the heat and it was not good. The heat on high is warm air at best. I noticed after installing the heater core that the heat wasn't as good. I didn't notice until tonight when I really needed the heat how pathetic the heat was.
With my old heater core, the heat would get extremely hot. You wouldn't even hold your hand over the vents for very long. I liked it that way.
The thermostat is only a year old and should be fine, the temp of the truck is normal.
The only thing different is the heater core.
The one I pulled out appeared to be aluminum. The one I put in looked like copper. It came from O'reily's Auto.
Could it be the antifreeze/water ratio?
Before I would just run 70% water and 30% coolant. Now, I'm running 50/50.
Could it be either of these 2 things or could it be the blend door?
