crazyye
- July 7, 2016
- Ontario, Canada
- 2013 Ford Explorer
Finally decided to join to vent regarding all the problems I have had with my 2013 Ford Explorer XLT 4wd. I must say I am very disappointed. I will be contacting Ford as multiple of this issues occurred more that once. The rear brakes are a joke... My ac compressor clutch failed twice in less than 4 year. See the list below... My wife sadly has lost faith in the vehicle and feels unsafe bringing our two young children in it. Twice the brakes seized while driving, and once caused smoke. We are scared that they'll be a tire blowout.
The sad part is I cannot afford a new suv or van.
2013 Ford Explorer - Delivered September 26th, 2012
June 9th, 2014 -17,798km - Rear passenger brake won’t release. Rear pads seized in anchor. Unseized and machine rear rotors. Inspect front rotors, also has heat spot. Replaced rear rotors. Warranty - no cost.
August 26th, 2014 - 19,124km - No air conditioning, clutch came apart, compressor seized. Brakes checked, 10mm in front, 8mm in rear. Warranty - no cost.
December 5th, 2014 - 21,027km - Steering making noise, lubricated steering shaft at steering gear. Warranty - no cost.
July 27th, 2015 - 26,594km - clips holding rubber seal all broke under hood. Steering still making squeaking noise. Replaced upper bearings on upper strut mounts. Brakes showed more than 50% on quality vehicle inspection. - Warranty - no cost
October 10th, 2015 - 29,104km - steering still squeaking noise, lubricated. Corrosion on hood, waiting on answer. - Warranty - no cost
April 4th, 2016 - 35,206km - rear brake pads and rotors had to be changed due to seized calipers. - $271 for parts, did labour for free.
April 18th, 2016 - 35,607km - burning smell from rear driver side brake, Dealer checked and said all was ok and that rotor heat was ok after road test.
June 20th, 2016 - 37,286km - No air conditioning, clutch failed and damaged compressor. Rear upper control arm bushings was finished, replaced by removing both rear wheels, rear calipers, parking brake cable brackets. Asked about the corrosion on hood. Service manager said that I was out of warranty. Told him I called for an appointment 2 weeks prior, and they were fully booked and that Oct 10th was their next appointment, and that they were made aware on the phone. Cost was $533 for a/c (told is was $1900, they goodwilled some of it), bushings $483 + $140 for alignment.
July 7th, 2016, heard noise from driver rear wheel. Jacked up suv and could barely turn tire. Brought in on the 8th.
