Fuel Filter Replacement. | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
newcomer91
1993 Ford Explorer XLT
The clips is fine.I dont know how to explain it.... it goes in but stops before it can click into place... i checked three places to make sure i had the right filter.
I heard you can cut the Mesh hose off and replace it with a rubber hose made for fuel injected vehicles? Is this true?
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
nooberiffic
Utah
93 XLT
did you cut it open yet? I'm curious to what the inside looks like after so long.
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Worst design Ive ever seen of a fuel filter... I completely changed the set up with compression fittings.. I now buy a filter for 7250 Case International tractor for my replacements.. takes me longer to get the shield off than it does to disconnect the and change the filter..Best thing I ever done to it.... I could not get mine to release with every different style tool they sell.... I took a hack saw to it
I agree... Not sure what te motive was to making this locking system that wreaks of issues.. on a fuel line no less.
going with a flare fitted filter, not a bad idea.
Sunapee, NH
05 Eddie Bauer
Thanks
I know it's an old thread but the info on this site is invalueable, I busted a clip today but was able to get one with the P/N here.
Thanks
Louie.
foodman392003
Chesterfield, Mi.
1998 sport 4x4,
old fuel filter
to nooberiffic,
After ten plus years and 200,000 plus miles of never being able to figure out how to take the fuel filter off i finally bought a tool and it came right off as instructed. I had to cut it in half to see what it looked like inside after so many miles and years????????????? To my suprise it looked like it was 6 months old and could go for another 200,000? Go figure huh? I wish I had taken a picture of it, you would not believe it.
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
I guess in 35 years of working on cars, I only remember one filter getting so bad that it impacted performance. Weird one, ford contour, I happened to add a can of seafoam to the tank and the weather went below freezing, something reacted with something else and it quit starting when it was below freezing. Replaced the filter thinking it had water in it. It had some dark blue goop.
mr cribb
US Army Retired
Harviell, MO
94 Chevy Z71, 93 X EB
I have yet to replace my fuel filter... bought the filter in Feb this year... it's still inside the truck.
I have no fuel issues... I will get to it one day....:rolleyes:
fireball 440
Location
Northern MN
minnesota
2015 Police Interceptor
That is a weird one. dark blue... what color do they die off road deisel?
The symptoms I'd guess bad ethanol blend gas, added the seafoam and it put the icing on the cake. (water seperation + more alcohol). Idk just a thought.
maroon93limited
Taber, Alberta
93 Limited
I changed my filter late last summer and was just curious as to what the purpose of unplugging the inertia switch is?
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
That turns off the fuel pump which lets you release pressure by running the vehicle without the fuel pump.
If you have a Fuel pressure tester, you can just use that to release the pressure..
In short, get the pressure out of the lines before you disconnect it or you will get full all over everything, including yourself.
~Mark
FIND
Vermillion, SD
99 XLT V8 AWD
Holy Thread Revival Batman!
Off Road diesel is dyed red. The blue goop he is talking about is probably particulate matter and other additives to the fuel that gathered over the years or oil (however it would have gotten in the fuel would be a mystery). But, someone could have put the wrong additive in the fuel at some point that the Seafoam could have diluted enough for the fuel pump to pick up. You never know.
Seafoam and ethanol blends wouldn't cause that otherwise. Seafoam will sometimes mix with heavier fluids that are at the bottom of a tank and cause them to be suspended in the lighter gasoline, which would then cause it to get trapped in the fuel filter.
Daniel77
Ohio
94 Limited 4.0
fuel filter replacment
Changed the fuel filter on my 94 explorer . was a bear to get the back side
off . the old filter when I dumped the gas out .the gas was like oil . (black )
Cant get the Ex to start right . Week end project
Maniak
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
does my 91 ford xlt have fuel injection
Yes, AND, the 1991 1992 use "batch fire" style of fuel injection.. You also have the filter that is being talked about in this thread..
If you have more questions about the fuel system (not about the fuel filter) start a new thread in this forum so your questions and the answers don't get lost in this thread.
~Mark
