BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
@410Fortune - Roger that and thanks! Appreciate your reply.
Yes... it's a PITA to do the fuel injectors... AND then have to go back in to address a vacuum leak! To confirm a vac leak, I'm going to do the "starter fluid" test first. This, along with the surging, no CEL, and the stethoscope test (injectors passed) will help me feel confident that a vac leak is in fact the issue. If so, I'll do the lower intake gasket, the EGR tube gasket, drill out the upper manifold per Donalds, and make sure all hoses fit snug.
I did the upper intake gasket late last year... at the same time I was doing the tensioners. I did both tensioners then.
If it still idles rough after all of this, I'll pull some more OBD data and go from there. Thanks again.
