Fuel Reset Button | Ford Explorer Forums
Fuel Reset Button
jeanniej62
MANSFIELD,OHIO
95 XLT
I HAVE LOOKED AND LOOKED FOR THIS BUTTON,DOES ANYTHING MAKE IT STAND OUT SO I CAN RECOGNIZE IT?:rolleyes:
open the passenger door
get down on your knees outside the truck
look at the carpet and where it goes up under the dash (by the passengers feet)
find the top of the carpet and pull it down
your inertia switch is under there.
unless you were in an accident it is really not likely your switch is bad or needs to be reset.
what problem are you having? Fuel pump is not coming on?
Have you checked the fuse and relay?
It Just Shuts Off While Im Driving And Wont Start Again,first Time It Happened It Started The Next Morning But Now It Wont.fuel Pump Is Coming On.
When it stalls, and the engine is dead--does the "check engine" light illuminate, or is it off?
Does the "Check engine" light illuminate when you first switch key on?
check engine light is on all the time? = Pull the codes
If the truck is just quitting on your while you are driving it is very likely the fuel pump relay is bad or the battery cables are corrodded.
thank you for your help,ill let you know how this turns out
I deleted your other post on this same topic for you. I'll move it to another forum. It might get more attention
If the fuel pump is turning on, your problem is not with the inertia switch for your fuel pump.
Maybe replace the fuel filter...
