FullBlownModz
- January 22, 2014
- Atlanta, GA
- 91 and 97 solid axle exes
Hey forum! After having a hub bearing go out to me on the way to work, i figured its time for the ifs to go. I went on Craigslist and couldnt find anything but housings and half complete d44s. I finally found a set of complete axles from a 77 f150. I got the full width hp d44, for 9 inch, all suspension components, 4 speed trans, and a np205 transfer case all for $500! Im about to be heading to college in 2 months so i plan for this build to be quick and have a limited budget. I plan on running 37 inch military tires on 16.5 rims which is what im running on my other sas 1st gen.
Parts needed:
Axle: moved forward ~2-3"
Shocks: monroe 13" travel shocks $45/shock
Set of 7 degree bushings- $55
SS Extended brake lines- $80
12" extended stock RA and custom tcase Crossmember (got a quote from my fab shop for $500)
Coil Spring Buckets $130
F250 Shock Towers- $40
drop pitman arm- $65
Coils- $160 (i want to run the 6.5 from bcbroncos but my buddy with an xj has new 8" rustys coils so i might get those if they will fit in the bronco coil bucket?)
track bar $130 (might get the stock one threaded to be adjustable)
Track bar frame mount $ 35
Steering $150 (i have the 77 power steering pump and steering box)
Tools & parts $150 (grade 8 bolts and nuts)
Gears and master install kits
New brakes (i want to use 78 tbird calipers but i dont think the fittings work with the extended brake lines)
Parts needed:
