1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
As we are all aware, the design of the 2nd gen rear wiper is horrible: it either doesn't have enough pressure to wipe the glass correctly or, when adjusted - one way or the other - to wipe correctly, gets caught under the bottom of the glass when parked. Owners of most of the 2nd gens around here, where it rains most of the year, just gave up and can't see a thing through the rear window. My solution: mount the arm turned a couple degrees ccw from the original parking position, making it rest at the bottom of the glass instead. This, of course, eliminates the convenience of being able to open just the glass, keeping the tailgate closed, which may be useful for carrying long items, for example. So this solution is not for everyone. If you do so, it's advisable to avoid mishaps by accidentally opening the glass with the wiper resting on it. I simply tied the loop at the bottom of the glass to a metal piece on the latch with bailing wire, but an electrical solution is probably more elegant. There is a small catch: the inside panel must be removed to gain access, and it cannot be re-installed with the glass closed without making a small cut in the top, to let the loop through. Comments?
