1995E
- July 16, 2010
- Maryland
- 95 + 11 Ex both XLT
After doing some research, I've decided to actually change my coolant.
It's been 5 years and I've done 46K miles with a bunch of road trips. I was originally going to put in Motorcraft Orange coolant in the car but I probably should stick to my Specialty Green coolant (Since my MY was 2011 before 7/11/11) since I don't know if the seals are different. Another thing that I am worried about is cavitation if the water pump is designed to the specific fluid. I don't know if the waterpumps are the same or not. If they are, I'll just change it to orange after 5 years. My main questions are, do I need to use a coolant flush if I am going to completely change my coolant or is that not necessary?
I have already bought the coolants. The prediluted orange for 1 gallon was around 13 - 14 dollars and the concentrated specialty green was around 30 dollars a gallon from the Ford Parts department at Koons Ford.
Just as a reference, I found all these sources about the coolants. Dexcool is the same as the Orange coolant if my research says anything. Is that true?
This is the list of the coolants:
https://www.fordparts.com/Products/Chemicals-EngineProducts-Coolants.aspx
which is:
Motorcraft Orange Coolant:
"Use when Ford Specifications WSS-M97B44-D2 or WSS-M97B44-D are specified"
"Meets or exceeds the requirements of WSS-M97B44-D2, GMW 3420 (superseded GM 6277M) and ASTM D 3306"
http://content.valvoline.com/pdf/zerex_dex_cool.pdf
"ZerexÒ DEX-COOL®
5/150 antifreeze coolant meets
or exceeds the following coolant specifications:
ASTM D3306 Ford WSS-M97B44-D
SAE J1034, J814 Saab, Opel Approved
SAE J1941 Navistar CEMS B-1 Type IIIA
TMC of the ATA
RP - 302B
GM 6277M DEX-COOL® Approved"
I am assuming the specialty orange is the same as dexcool so is it safe to just buy Dexcool and use that?
Here's the info I found for Specialty Green coolant which similar to this:
http://content.valvoline.com/pdf/zerex_asian_vehicle.pdf
"Hyundai / Kia MS 591-08
Toyota / Scion / Lexus
Honda / Acura
Nissan / Infinity
Mitsubishi ES-X64217
Subaru
Mazda / Ford WSS-M97B55-A
Suzuki
Isuzu
Dae Woo
Daihatsu
JIS K2234-1994
ASTM D3306
ASTM D4985
SAE J1034, SAE J814, SAE J1941
Federal Specification A-A-870A"
The only difference is that I found was that the Specialty Green has phosphates while the Orange has no phosphates. Both are free of silicates. So the Specialty Green is hybrid OAT and the Dexcool is a full on OAT.
http://www.motorcraft.com/servlet/B...here=1249081817307&blobcol=urlblob&blobkey=id
I found this article very helpful in explaining the differences: http://www.machinerylubrication.com/Read/841/coolant-fundamentals
which is:
"ZerexÒ DEX-COOL®
TMC of the ATA
RP - 302B
Honda / Acura
Nissan / Infinity
Subaru
Suzuki
Isuzu
Dae Woo
Daihatsu
JIS K2234-1994
ASTM D3306
ASTM D4985
