headlight unlevel ???
DR.J
Blue Springs MO
2015 Explorer Blk/Blk Lim
my 2012 ex limited, i have noticed that the right headlight is higher than the left just a smedge..... it reminds me of looking at ones eye glasses and the bifocal on one side is lower.... anyone else notice this
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Dr.J.:wavey:
Just to confirm, you are talking about the headlight itself and not the light pattern it throws out?
VinceL
Frisco, TX
2013 Explorer Limited
If you are referring to the pattern, the left light is often aimed a little lower to help avoid blinding oncoming traffic.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
It is nornal with HID lights.. as said, left is lower to prevent blinding oncoming traffic with HIDs.
DR.J
Blue Springs MO
yes the pattern is what i am talking about...
the equinox that we had were straight across... my f150 is straight across... people even have blinked their bright lights at me...
just thought is was different.....
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
The F150 didnt have HID and I am assuming the Equinox didnt either. Halogens are straight across, Hids are uneven because they are brighter.
Smoktya
Bethlehem, PA
2011 4WD XLT
i am having the same issue. Lately, i have been getting the "high beam" strobe at me from on-coming traffic. Last night my wife was following me in the explorer and the driver side headlight (non HID) definitely gives the indication of high beam. The passenger side light looks fine, but the driver side definitely blinds you. I am guessing i can just pull up to my garage and make the changes myself by aligning some screws a little better. Is this in the manual, because if it is I must have missed it
VinceL
Frisco, TX
Yeah, the procedure is in the manual. It provides a bunch of measurements for the light pattern for you to match.
peterk9
Staff member
Moderator
Callsign
VE3
As Vince mentioned, it is in the Owner's Guide. Check the index under Headlamps/Aiming. Adjustments can only be made vertically, not horizontally. This applies whether you have halogen or HID headlamps.
B 2015 Explorer XLT LH Headlight Bulb Replace Stock 2011 - 2019 Ford Explorer Discussion 5
R Yet another headlight complaint..... Stock 2011 - 2019 Ford Explorer Discussion 2
A Headlight will not come out of assembly Stock 2011 - 2019 Ford Explorer Discussion 1
V Exploded View of Headlight Assembly needed ?? Stock 2011 - 2019 Ford Explorer Discussion 0
T Driver side headlight issue (2019 XLT) Stock 2011 - 2019 Ford Explorer Discussion 4
E Headlight connector part # Stock 2011 - 2019 Ford Explorer Discussion 7
F Level setting headlight Stock 2011 - 2019 Ford Explorer Discussion 4
P Headlight upgrade-update/review Stock 2011 - 2019 Ford Explorer Discussion 4
D 2015 Basic Headlight Question Stock 2011 - 2019 Ford Explorer Discussion 12
E Headlight connector pin out Stock 2011 - 2019 Ford Explorer Discussion 0
I Headlight Replacement Stock 2011 - 2019 Ford Explorer Discussion 9
F Headlight question 2016 PIU Stock 2011 - 2019 Ford Explorer Discussion 22
E Headlight ballast difference Stock 2011 - 2019 Ford Explorer Discussion 6
B how to tap into headlight wiring 2016 sport? Stock 2011 - 2019 Ford Explorer Discussion 5
Watcher58 Headlight pattern Stock 2011 - 2019 Ford Explorer Discussion 8
R Osram Xenarc Headlight Bulbs Stock 2011 - 2019 Ford Explorer Discussion 5
D Right headlight won't work, can't find fuse? Stock 2011 - 2019 Ford Explorer Discussion 13
B 2014 Explorer Right Headlight Flickers On and Off Stock 2011 - 2019 Ford Explorer Discussion 3
Rainlord Small light inside headlight not working, or am I missing how/when it works? Stock 2011 - 2019 Ford Explorer Discussion 2
T Headlight not working...need help please Stock 2011 - 2019 Ford Explorer Discussion 51
E Headlight Performance Review Stock 2011 - 2019 Ford Explorer Discussion 14
N 2017 headlight swap Stock 2011 - 2019 Ford Explorer Discussion 26
M 2016 Limited Headlight Issues Stock 2011 - 2019 Ford Explorer Discussion 8
L Best halogen headlight bulbs, 9005 or 9011? Stock 2011 - 2019 Ford Explorer Discussion 83
R Automatic dimming headlight installation. Stock 2011 - 2019 Ford Explorer Discussion 4
F Headlight not working, but bulb is OK Stock 2011 - 2019 Ford Explorer Discussion 5
N LED headlight out already Stock 2011 - 2019 Ford Explorer Discussion 39
C HID Headlight HELP! Stock 2011 - 2019 Ford Explorer Discussion 21
K Headlight bucket removal Stock 2011 - 2019 Ford Explorer Discussion 7
k9gold 2016 - 2018 Explorer Headlight Question Stock 2011 - 2019 Ford Explorer Discussion 167
N 2016 Explore LED Headlight Kelvin? Stock 2011 - 2019 Ford Explorer Discussion 1
B Replace headlight assembly 2015 explorer Stock 2011 - 2019 Ford Explorer Discussion 6
G Automatic headlight and DRL questions. Stock 2011 - 2019 Ford Explorer Discussion 15
E Question on how to remove headlight on 2013 Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 13
I Headlight "de-laminating" Warning Stock 2011 - 2019 Ford Explorer Discussion 12
D 2013 Explorer headlight problem Stock 2011 - 2019 Ford Explorer Discussion 5
P Headlight bezel issue? Stock 2011 - 2019 Ford Explorer Discussion 14
R Headlight adjustment screw Stock 2011 - 2019 Ford Explorer Discussion 18
N Moisture in the headlight assemblies 2013 Stock 2011 - 2019 Ford Explorer Discussion 5
J Headlight Protection Stock 2011 - 2019 Ford Explorer Discussion 13
G Where to find replacement headlight dust/moisture caps? Stock 2011 - 2019 Ford Explorer Discussion 2
J how to install replace headlight ford explorer 2013 Part Number: 13008 Stock 2011 - 2019 Ford Explorer Discussion 2
B Quick Headlight question Stock 2011 - 2019 Ford Explorer Discussion 14
V Headlight armor Stock 2011 - 2019 Ford Explorer Discussion 8
J Headlight adjustment Stock 2011 - 2019 Ford Explorer Discussion 1
D 2011 explorer headlight help? Stock 2011 - 2019 Ford Explorer Discussion 8
M Lightning Eyes Headlight Kit Stock 2011 - 2019 Ford Explorer Discussion 11
G 2011 Ford Explorer Headlight Problem Stock 2011 - 2019 Ford Explorer Discussion 2
Similar threads
