Rbcoddington
- October 9, 2018
- 2016 Explorer Limited
hi everyone-
We have a 2016 explorer limited, I have a question about the heat/cool seat settings. The settings have always turned off when the car is shut off and you have to manually put the settings back on when you start the car.
Well we took it into the ford dealership and they worked on the navigation system.
We got the car back Friday and now the heat/cool seat setting & heat steer wheel stay on the previous setting. So if you have it set to 2 on cooled seat, when you turn the car off & back on it automatically goes to that last setting.
It’s not a big deal to us but I’m concerned that they might have messed with more than just the navigation system.
Do the newer models default to the last seat climate setting when you start the car, or you manually have to turn them on each time you start the car?
Just not sure if we need them to fix this issue since it just appeared after they supposedly worked on the navigation system?
I called them and they said it’s fine & nothing to worry about. Thank You-Ragan
