Zachj83
- January 7, 2017
- Boise, ID
- 1993 Ford Explorer XLT
So... 1993 Ford Explorer, 94K miles, original everything (as far as I can tell). It takes quite a while to reach normal operating temp (almost 5 minutes, sometimes more), and then when it does, the gauge jumps back and forth from the "N" and "L" in normal. It is never stable on the gauge; it's always moving. Also, the heat does not work. The fan blows good air, however the air coming out of it is about the same temperature as the outside air.
Things I've tried:
Coolant flush
Replaced thermostat (twice)
Checked radiator, reservoir, and hoses for leaks/air bubbles
Also, the hoses both TO and FROM the heater core in the firewall do not get hot to the touch. They get warm-ish. The upper and lower hoses for the radiator are also about the same. They get hot... but not as hot as they should. It's almost as if the engine isn't getting hot enough. But that doesn't make a whole lot of sense. Any help would be appreciated. Thanks!
Things I've tried:
Coolant flush
