tomblin1
- April 27, 2003
- San Diego, Ca
- 1993 XLT 4 door 4X2
I never heard from flaming river.
I solved my problem 90% by changing out the steering shaft with one from a '91 Explorer Sport. This one had a nice u-joint at the top and a rag joint at the bottom. My original one had a rag joint at both ends. The u-joint is much smoother, steering wheel returns to center if i let go after completing a turn with no problem now.
Look at the photos that udmsvt posted, the first one is of the stock rag joint, the second is the shaft out of his 91. You can see the diffence in the type of upper joint on the shaft. This is what I changed mine with.
I picked it up for $50 from a salvage yard and switched it myself. not hard to do. Took 30 minutes.
From my understanding, if Flaming River makes one for our Explorers, may cost around $200 and bascially has a u-joint at both ends. I'm very happy with my solution. It was cheaper and really helped.
Good luck!
Good luck!
