help!! mystery wire... | Page 2 | Ford Explorer Forums
yaaahuuuu
turdle! if u could jus hear her purrr
it was the spark plug wire, the driver side were all backwards
shes working jus fine now, im going to take her for a spin to make sure
i really appreciate your help man! my first day of college is monday and this was the last thing i needed!!
thanks again
they all seem to be in the right place but is it possible tht they could be in the wrong way..like if i have to turn the injector 180* and reinsert it?
Make sure all injectors make a click---you can feel for this with your fingertip
when u say fireing order do u mean the ignition wires to the coil could have been put in wrong?
I have done it--more than once;)
dammit
spoke too soon.
the fuel pump is not whinning so its has to be a loose wire tht made a good connection a few hours ago but came loose again
ill find it
Hmmm
try this
leave the key switched on, and try manipulating all off the connections, one by one.
you might get lucky and cause the pump to run, when you mess with the right wire.
This will not fix the issue of course, but it might show you what to fix.
