Maxmax19773
- March 6, 2020
- Location
- Galleria
- Houston tx
- 2002 explorer sport 4.0
Hi guys. Finally put everything back together. Did front and rear cassettes replacement. I have no idea where I messed up . I Can’t hear Fuel pump when turning key on. (Pump replaced probably 10 months ago. Bosh). Could be something simple like forgot to connect something?). I got reman injectors from eBay installed. ( reputable seller. Don’t think they faulty) . New ignition coil denso … , could be ground wiring?? . Car had no battery for 6-7 months. Could be pcm? I check the fuse 23 it looks okay. Checked relays if they loose. I timed everything right- no doubt about it. Crank position sensor? Could it be a safety switch on the passenger side under dash?? I am terrible at diagnosis) maybe I mention a lot of stuff not related to the issue) but I have no clue where to start. Any help appreciated. Thanks in advance.
