Biggamer89
- April 27, 2025
- Ohio
- 1999 Explore sport 4.0ohv
Hello if anyone can help my 99 explorer sport two door 4.0 ohv about 4 to 5 years ago I bought the truck and purred like a kitten five-speed four-wheel-drive and all of a sudden it starts running like it’s running off five cylinder not horribly probably 5 1/2 cylinder it wasn’t bad enough to stop driving it so I was driving Daily driving and every day it would get a little worse over about a month Period. All of a sudden it starts running really horrible probably four-cylinder and then started having starting issues wouldn’t want to start at all just popped started up shut off and then nothing Sounded like I completely lost fuel or spark or timing. So I figured crank sensor bought a crank sensor put it on it nothing and then I started looking at the fuel I didn’t have a pressure gauge at the time so I just push the needle and gas goes flying so I was pretty sure that wasn’t it. So I bought a cam Sensor and so on and so on I replace parts for five years could not figure it out until one day a guy told me that that truck has two cam sensors and so on and so on I replace parts for five years could not figure it out until one day a guy told me that that truck has two cam Sensors. So I start looking into that and I find the synchronizer instead of a distributor which I wasn’t used to never replaced one but sure enough soon as I put the synchronizer in the back of the engine which is a pain the first time! Anyways it fires right up biggest smile on my face I think I’ve ever had all of a sudden I hear a knocking so I instantly look at the oil pressure gauge and it’s at zero so I kill it figure I must’ve either got the timing wrong so I go back to scratch make sure that I got it all 100% timed Compression stroke Tdc From the zero mark on the harmonic balancer. And bam it hit me I crank the engine over without the synchronizer in the hole so the drive shaft must’ve bounced and landed in the bottom of the pan still not 100% if it did? There’s not a lot of YouTube videos was a waist time watching them! One guy made a homemade tool that you can reach down in there with and grab The shaft and reinstall from the top of engine And get it back in the pump. Well he didn’t show how to make the damn thing so here I’m trying magnets and everything else Hoses couldn’t get it.. But then all of a sudden I go out the next day fire it up no knocking oil pressure gauge is halfway up good oil pressure wtf? Now I’m left with 22 codes no oil pressure and knocking again I have codes for Camshaft Sensor circuit Fault was the very last code I received after running it today.
