High milage explorers? | Page 19 | Ford Explorer Forums
Originally posted by thudson
she is running well but there is a strange sound coming from the front left wheel..... almost like something is rubbing on something or something is Warped and when it goes round it is scraping on it…. I cant explain it any ideas?
Might be a wheel bearing.
99 Sport 4x4 116,000
Having concerns about rattling under the car. Sounds like something in the trans pan
i had that... are you sure its not the heat shield on the exhaust..... my dad did something to it and its stopped now .
I checked the heat shield and it sounds fine and I just had the converter repaired.
My '97 XLT (4.0 SOHC) has over 100k on it now and the only thing that I've had to replace is the t-stat, and do regularly scheduled maintenance on it like oil changes, brakes, tires, etc. Now my air conditioning isn't working...:(
can you hear the A/C clicking on and off?
Just thought I'd add in my info, wow this thread is so old!!
I have a 1991 Eddie Bauer with 143,000. It had about <90,000 when I got it.
The tranny was rebuilt at about 100k but the shop said it had been rebuilt previously as well, so thats two tranny rebuilds. The water pump blew at about 135k which led to the intake manifold at 135k and a leaking radiator at the same time which led to bearing material being found in my oil along with coolent so replaced the engine at 135k miles. Though it still ran better than the day I got it!! And had more power than from the factory new!! Would have eventually thrown a rod though. Ok now that is has 143k I had an inspection done and this is what needs to be replaced and fixed, Upper and lower ball joints both sides, three front axle u-joints, hub seals, radius arm bushings at the frame both sides. And thats pretty much it for major stuff. The early generatino explorers are amazing, this truck will last till 200k I bet. And if it wasnt for my stupidity of offroading with a cooling problem then I would still have the original engine in. The engine in it now has 90k and runs perfect with perfect compression as well. Too bad I may be selling the truck in three weeks :(
1996 Sport with 183,000 miles and around 20 miles to the gallon.
Replaced-Transmission, brakes, tires, fuel pump.
sweet thats about what i have done to my 130,000 mile second gen - the fuel pump
thudson...what about the a/c click on & off..that`s normal ?
from what i understand that is normal, mine does it and in traffic I can hear many other makes and models that do it. I guess it has something to do with cycling the ac on one in a while in order to maintain the system or keep condensation build up, im not sure thouhg, but I do know its normal.
The A/C clicking sound is just the compressor turning on and off, its normal, so dont be worried guys!!
Did I mention it has never leaked anything!
yeah its totally normal... but if its not clicking on and off then he should check his A/C clutch
'93 Sport
125K Miles
Alternator, Plugs, Starter, Radiator
Runs a little sluggish, but I haven't touched
the injectors yet.
95 xlt 4x4 with 134K.
just acquired last week. got a new t-case motor saturday, new dash light bulbs.
had a tranny rebuild at 121K. Needs front brakes. Radio lights don't work, but display and radio work just fine. 4wd lights go out when headlights are turned on. That's about it. Hopefully, it will last quite a long time.:confused: :confused:
1993 Limited at 202,000 highway miles...
replaced radiator, radius arm bushings, thermostat, new clutch fan... It leaks oil at the rear seal and oil pan, but hasnt been fixed yet.
Also 1997 Explorer Limited 89,000 miles just recently bought it few months ago never had problems yet :)
Recent repair woes at 80K
At 80K, my '97 XLT AWD (V8) needed significant repairs, which pissed me off because it was great at the 65K checkup and I maintain the sh*t out of it. Here they are (not including regular maintenance and checkups):
25K: mal***tioning remote antenna - repaired under warranty.
28K: loose left rear window motor - repaired under warranty.
35K: intermittently failing manual door lock switch - never repaired, hasn't re-occurred.
60K: Cruise control light burned out - replaced myself with bulb from Taurus, cuz the "module" direct replaceemtn was $110. Had to remove airbag...bad design IMO.
65K: Leaky rear pinion gasket on driveshaft - had dealer replace $85.
80K: A/C hose split - no A/C, needed all 4 ball joints replaced up front, new control arms and bushings, new front driveshaft to fix bad bearing noise, rear brakelight not working ($400!!), O2 sensor. Total cost (I did the brakelight myself): $2100!!
schadler~ hey dont complain... you have a truck that cost around $32,000 brand new.... 2100 bucks isnt bad at all. your talking about 6% of the cars initial value in repairs. If you cant afford the repairs, dont buy such a bug vehicle. Remember, nothing is trouble free!
