Recent repair woes at 80K
At 80K, my '97 XLT AWD (V8) needed significant repairs, which pissed me off because it was great at the 65K checkup and I maintain the sh*t out of it. Here they are (not including regular maintenance and checkups):
25K: mal***tioning remote antenna - repaired under warranty.
28K: loose left rear window motor - repaired under warranty.
35K: intermittently failing manual door lock switch - never repaired, hasn't re-occurred.
60K: Cruise control light burned out - replaced myself with bulb from Taurus, cuz the "module" direct replaceemtn was $110. Had to remove airbag...bad design IMO.
65K: Leaky rear pinion gasket on driveshaft - had dealer replace $85.
80K: A/C hose split - no A/C, needed all 4 ball joints replaced up front, new control arms and bushings, new front driveshaft to fix bad bearing noise, rear brakelight not working ($400!!), O2 sensor. Total cost (I did the brakelight myself): $2100!!
