High speed wobble | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
High speed wobble
OC sporttrac
Ocean City, NJ
2004 explorer sport trac
Brand new to the board. Thanks for having me.
I have a high speed wobble that I can't seem to get a correct diagnosis. When I am moving on a highway or off ramp, if I hit a bump straight on, then no problem. If I hit it slightly turned I get a shake in the steering wheel. Enough that it really concerns me. I had the ball joints replaced last spring. Uppers and lowers. Shocks were replaced about 40,000 miles ago
Truck has 110,000 miles. Since I moved to the beach 3 years ago, I'm having a lot of front end problems.
Thanks for all the help
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
OC sporttrac
Ocean City, NJ
I'm following up on this post in case anyone has similar issues. I drove to PA (100 miles) and had an ok drive. I got about 3 miles from my destination and the truck started doing weird things. Every time I turned left it felt like I was in a severe under steer/sliding. I finally took it to a pro (very rare) and he couldn't figure it out at first. The issue was there was no sound. Turns out it was tread separation on the left front tire. Someone was looking out for me.
D Hook
Omaha, NE
06 Explorer Limited V-8
Thanks for posting the follow-up.
fusseli
2002 4.6L
I had shaky stability problems hitting bumps on the highway, it turned out that my rear sway bar was broken. I would check everything in the front end as closely as you can, control arms, ball joints, sway bar, end links, tie rods, etc. Any play anywhere means something is shot.
OC sporttrac
Ocean City, NJ
Thanks for the sway bar suggestion. I had checked all connections, just did check the tires. I put new tires on and it's all good. Great set of firestones for 500 installed at tires plus. Everything can be negotiated.
