Teddydog
- April 14, 2008
- Dupont, WA
- 92 Explorer XLT
Since I'm getting a cheap used hitch, it won't have any instructions. Not concerned about fitment (have read the stickies), but how should the bolts be torqued? Anyone have a figure? Should I get new bolts, or is reusing the ones from the "donor" X OK?
When installing a transmission cooler, is a full drain needed? Or do you just top it off for the new volume? I'm sure the cooler will have instructions (NOT buying that used), but I'd like to know ahead of time. Does it get messy when adding in the new lines, or is the fluid loss minimal?
Thanks!
Rob
Thanks!
Rob
