aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
I wanted to determine the effect of the location of the supplemental B & M transmission cooler on ATF temperature.
As reported ( post 29 above ), the metal bumper more or less blocks direct air flow to the transmission cooler ( less than 1 inch below bumper ), for that reason, I decided to investigate ATF temperature on a highway run ( ~70 MPH ) with the cooler in its current location ( picture 1 test 1 ) and the repeat the test with the transmission cooler relocated to a vertical position ( like Kevin { MONMIX } did - picture 2, test 2 ). The vertical mounting location allows 5 ½ inches tp protrude below the bumper. Both of these tests were conducted with the metal bumper frame ( only, no cover ) in place.
The repositioning of the transmission cooler was quite simple. All that was needed to do was drill two new mounting holes and attaching the cooler with screws with lock nuts and to shorten one of the rubber lines; took less than 10 minutes. The removal of the metal bumper took about 10 minutes ( remove 4 nuts and disconnect the fog light connectors ).
The predetermined test parameters were as follows:
Distance and speed were GPS ( Dead Link Removed ) determined, ATF temperature was determined with a digital transmission temperature gauge, oil temperature was determined with a digital gauge ( http://dakotadigital.com/ ) and coolant temperature was determined with an OBD II scanner ( http://www.autoxray.com/default.htm ).
For test number 1
30.4 mile highway ( I 75 ) run at 70.46 MPH.
Ambient temperature – 94 F
ATF temperature – 134 F
Coolant temperature – 190 F
Oil temperature – 200 F
For test number 2
30.8 mile highway ( I 75 ) run at 70.67 MPH.
ATF temperature – 131 F
Simply relocating the transmission cooler resulted in a decrease of 3 F in ATF temperature. The extra air flow is a good thing. This simple mod was well worth it for me.
After carrying out these assessments, I decided to replicate the highway run with the bumper removed ( picture 3 ) to determine if completely unobstructed air flow had any effect on ATF temperature.
30.4 mile highway ( I 75 ) run at 70.02 MPH.
ATF temperature – 128 F
Oil temperature – 199 F
Air flow is a very good thing when it comes to cooling ( a decrease in ATF temperature of 6 F ). Once I get the bumper cover installed I plan to fabricate sheet metal or plastic air deflectors to channel the air to the cooler.
As an aside, I noticed that the front end of my truck definitely felt different with the bumper off at highway speed; it felt less stable.
For test number 1
For test number 2
