- April 2, 2000
- Greenville, MI
- 98 Mountaineer 5.0 AWD
When you straight wire lights you are running all the amps for the lights through the switch. Most switches are not ment to handle the amps of a light set. So they wear out quicker. Also if there is a problem in the wiring (short ect.) and it causes a wire to burn, it could be burning in the passenger compartment. ( fire under the dash at 70MPH is no fun) Also when you run the wires back and forth from the battery to the switch and back to the lights unless you are using the correct guage wire the will be a voltage drop and the lights will not be as bright as they could be.
Relays are used for safety and to get the most light out of a light.
I'm not a safety conscious type guy but I am a light brightness type guy. Not using a relay usually means you are not getting all the lumans from the light. So, why do it if it isnt bright???
