Dano!
- September 14, 2010
- Lemoore CA
- 91 Navajo X 2
I very recently did this, I was lucky enough that a previous owner had ground the rivets off, on my particular project I replaced the RA brackets on both sides and the bushings.
the only things I would like to add is..
1. The Moog replacement RA brackets come with bolts that fit into the holes left by the factory anchor nuts which is very convenient.
2. The 4 bolts connecting the two RA brackets together all have anchor nuts designed to catch on a flap of metal which means you dont have to hold the nut with a second wrench. Those 4 anchors fit the replacement bolts Moog included in their RA Brackets. So after you drill/cut the rivets off you can save alot of time using those anchor nuts to bolt the new brackets on.
3. Energy suspension poly bushing kits do not come with the metal plates that go along with the RA bushings. But the Moog RA bushing kit does come with new metal plates. I was able to use both kits to replace everything.
4.the Moog RA bushing kit does not come with a heat shield. Purchase it separately.
5. Place jack stands on the frame in front of the transmission cross member.
6. To help align the passenger RA, you can jack it up with a floor jack. Once its lined up just screw the nut on.
those are all the lessons I learned. I hope it helps.
