How to: Interior lights on - Door Ajar | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
If you have handle controlled interior lights and they are always staying on and you have the door ajar light on, you are going to love this fix.. It's an easy and a cheap fix, and is the way to perform your maintenance of this switch...
Put your fuse and bulbs back in, roll your windows up and get a can of wd40 with the straw...start with your drivers door...from the outside pull the handle up and where the handle goes thru the door, squirt a little wd40 in both those slits...open the door and just work the outside handle a few times...go to the passenger door and do the same....thats all there is to it...good luck...:D
Update
...If you have an X, You may also need to wd40 your rear hatch latches and If this does not fix your problem and this is a normal fix, you may have some other issues so please read post #8,#12, and 13 of this thread...;)
...Maybe a broken wire could also be your problem??
http://www.explorerforum.com/forums/showthread.php?t=223988
elmo4fun
Phelps, NY
99 explorer sport
yup latches on both doors and both latches on the hatch. the passenger door is the only one that dosnt ding when i open it. i have had the dor pannel off and tried to lube everything on the inside to.... no luck.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...have you looked into the other threads i had noted here???
elmo4fun
Phelps, NY
99 explorer sport
yeah...didnt help. i ended up disconecting it at the switch. seems to be ok now. just the dome light wont come on with the passenger door. no big deal.
Tbars4
Moderator Emeritus
Elite In Memoriam
...if you contact kbabiak on the bottom of the forums page he can get you a switch...;)
IllusionX2k3
Staten Island, NY
99 XLT
I have a similar problem like this, My interior lights stay on after the doors are shut, when installing my alarm it said all my doors were open. My door ajar light is blown out, changed it and it just went out again, probably from being on all of the time. I tried the Wd-40 trick and got nothing. Think its my GEM Module?
Btw I have a 1999 Ford Explorer XLT 4.0L 4x4.
Tbars4
Moderator Emeritus
Elite In Memoriam
...it could also be how your alarm was installed...:scratch:
WendySanDiego
San Diego California
It seems I am not alone
I see there are many others with the same glitch.
I have a 96 Ex. Sport
8" lift, huge tires, and all the other (cr*#) this breed of Ex. implies!
4 speed
All auto
air
deluxe all around.
whoopie!
I bought it this way.
(It was a deal from a realtive story)
so it has always had a glitch with the ingnition.
That I was fine with.
now, it's the door adjar light (always on)
dome light wont turn off for 30 min.
it's killing my battery now.
oh wait,
please!!!
can N E 1 tell me if this Ex.has a clutch that be adjusted?
thanx guys!
Wendy
Donner
Natomas/Irvine
01 Sp 03 XLT 4x4s, Scion
This is going to be good!
4 speed
All auto
air
deluxe all around.
whoopie!
oh wait,
please!!!
thanx guys!
Wendy
Well, being short on answers for you, I just wondered if you had a pic of said breed... Sounds like a something to behold! :popcorn:
What's up with the clutch?
WendySanDiego
clutch ?'s
hi, thanx again for trying to help.
I have had many standard tran. vehicals.
I can tell when the clutch is starting to go.
Slipping, rev-ing,, you know......
I was told by someone that I probably need a new clutch.
Then, told it may only need an adjustment...............
does the 96 Ex. Sport have an adjustable clutch?
thanx,
Wendy
cybergasm
Humboldt Ks
1997 Mountaineer 5.0
WendySanDiego:
Sorry tried replying to your e-mail but my e-mail client is being a bit fussy tonight
but i did get it tho :D
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Some people experiencing a door ajar code may notice that they are having problems with 4 X 4 low as well. The power door lock sticking will set this code with the GEM module, and cancel 4 X 4 low. This article in the January/February issue of Gears Magazine addresses this issue on a 1999 Explorer. The main point of this article is to address that 4 x 4 won’t engage occasionally when the transfer case is in the low range. Here is a link to this article: http://gearsmagazine.com/images/issues/2_2008/2008_1_30.pdf. Ford acknowledges the problem with the older style door lock which causes the door ajar issue. They have a redesigned power door lock to replace it.
Tbars4
Moderator Emeritus
Elite In Memoriam
...thanks brooklyn for the heads up and the link...:thumbsup:
Crvtte65
MA
'02 Limited
Worked for me!
I forgot to post when I registered but I just bought an '02 explorer and noticed this issue. WD-40 worked great!
Now, to tackle the issue of the cold-weather induced door latch not working...
Tbars4
Moderator Emeritus
Elite In Memoriam
...i'm glad to hear it worked for you and thanks for posting this as so many just forget to...:D
jjstunts
2002 4dr eddie bauer
why me
Just bought a 02 ex, eddie bauer,
2 weeks later I get the door ajar problem. No bells ding on any door, lights stay on and I get a dbl horn honk when setting the factory alarm. please help.
What is the GEM module?
Any wire I should just cut?
Tbars4
Moderator Emeritus
Elite In Memoriam
...did you try the wd40??? :scratch:
jjstunts
no wd40, after reading the thread I figured that only works when you can locate the faulty door by a no ding when open. Guess I should try it anyway huh.
I'll have to go get some though
cmhafull
Elizabethton, TN
02 Mountaineer
thanks for the info it really worked
BrooklynBay
Staff member
Moderator
Brooklyn, NY
