Themightyquinn
- November 11, 2011
- Philly, PA
- 2007 Eddie Bauer 4.0L AWD
Does anyone know how this would compare to the 8.8 IRS?
I know this is older but I have the same rear end but my axle shaft broke on the outer end where the lugs are and I can't remove it. The c clip is out and everything but I'm stuck and have no clue what to do. There's not enough axle sticking out to pull it. Any ideas? I'm desperate here I need it fixed by noon tomorrow, any ideas are greatly appreciated. I've tried pushing from inside the diff also.
I was afraid I was going to have to do that. Which pin are you talking about? Thanks for responding I am pretty frustrated here and can't afford to pay a shop to do it. I'm assuming I will need to replace the other axle shaft seal and bearing as well?
I replaced the passenger side rotor, axle shaft, seal, bearing. Everything else went back as it was. It sounds like maybe I don't have enough gear oil in it or the wheel studs on the new axle aren't in all the way. Its driving fine minus that noise but the noise concerned me enough I turned around and came home on my test drive. Question, would running a 235/60 17 on one side and a 245/70/16 cause that noise? Since the spinning radius is different? I'm thinking about buying more gear oil and adding it to see if that eases the problem. I can't describe the noise but I know it can't be good. Maybe its the new studs not completely pulled against the axle?
I'm switching them now, does 2 QTS sound right or should it be more? I do use the search button but hard to find a definitive answer
