DintDobbs
- January 29, 2020
- Location
- somewhere in the swamps
- NC
- 1999 Explorer Sport 4x4
@Kidd7 Incidentally, @DemonMudder found that replacing his IAC corrected a similar issue. Consider checking out his thread, specifically post #1042 describing his problem:
www.explorerforum.com
and post #1074 describing the final solution:
-Deathrow Update Log-
Keep going is the goal. I have to fix the pinion bearings in my work Explorer this weekend etc. I don't have a way to rebuild the rear, so I'll be swapping the rear from my Mounty, and the diff's between them. I have a Torsen in my Mounty which has been great for my needs. I don't want to let...
https://www.explorerforum.com/forums/threads/what-are-the-valve-body-torqe-specs-5r55e.180919/reply?quote=1619444 Voila... Thank you so much!
