army1959
- June 23, 2018
- dallas tx
- 1998 ford explorer
1998 ford explore 4.0L ohv 6cyl
so for the last 3 months i keep getting these codes every 5 to 7 days the p0174 code has not come back once i changed the fuel filter ;
the next thing i did was try to clean the mas but it was original part and it would not come clean so i replaced it as well as the metal hosing , original had a small crack
that lasted 2 weeks , and again p0171 showed back up so i did a smoke test no leaks , but to be on the safe side i changed the vacuum lines i could tell they were getting bad , 7 days latter p0171 so i changed the pcv valve and hose good to go, 5 days latter you guessed it p0171 , ok so took it in got a fuel pressure check it passed .
next i did a tune up new plugs wires and coil pack , the old one was original and i could see signs of wear on it , good to go for about 4 days and here it comes again p0171
did another 4 smoke tests , nothing the last smoke test i let it run for 45 minutes got under the car could not find any thing put it in the tail pipe to see if there were any leaks in the exhaust manifold nothing , today i pulled out the air idle control and cleaned it ,it needs to be replace as its the original . but no codes i drove around for about 25 miles checked the im and it was green across the board . but my OBD2 Scanner
it showing pending code of you guessed p0171 , i'm about ready to put the explorer up for adoption
so any help would be great please i don't want my ford in foster care
