- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Above you are seeing the barbed end which is so special, the barbs are larger in diameter than most, and they have a very sharp back edge which bites into a hose.
The push lock fittings used to be very basic, NPT/barbed in various sizes. Now most any hydraulic hose supplier can get dozens of different choices. I like the flare fittings of the OEM(on the radiator and trans) because they don't leak.
The aftermarket flared fittings do commonly leak at the joints that you create, a slight but annoying leak. I think it may be manufacturing tolerances. When you assemble one of those joints next time, look at the female end and notice a "valley" in the bottom where the other end will seat. That space is usable for an o-ring to seal the parts better. I always buy an o-ring for those which fall right into place easily. That seals the joint with far less torque than is required without them.
