- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Can I use a 91 or 92 cluster in a 93?
Reason I ask, Is I am having issues with my 93. Fuel gauge and temp gauge do not work correctly. Upon investigating I saw a prior attempt at repairing the circuit on these 2 gauges. The fuel gauge is non responsive, and temp gauge pegs. All other gauges work fine as far as I can tell.
So, I swapped in a 91 ( or was it 92?) navajo panel. Now I get alternator pegging to the negative, fuel pegs to way over full as well as oil pressure pegging to the right when the key is switched on. I did not reconnect the speedo cable yet.
seems like a ground issue, but where?
I did notice the color of the ribbon circuit ( mylar film stuff with copper circuits) was different-Navajo is blue and the original is a pink color.
Thanks for reading.
Thanks for reading.
