So, this winter I'm considering storing the trailer on the side of the house, vs in the garage (to free up space!). Our side yard is about a foot and a half wider than the trailer, so enough to snake it in, but not wide enough to slide a jack in to put it up on blocks (so that the tires arent bearing load). I assume not, but are there other solutions than praying when I pull it back out in spring the tires wont have flat spots? I know they have those contoured things to prevent them- do those work? I would assume for them to be effective they would have to perfectly match up to the contour of the tire.... Are there other options that could get blocks under? Not sure how to get a jack under to the axles when I couldn't even get on the side of it probably... The only idea I can think of is a lift... but that's not happening!!! I assume not, but if anyoen has some ideas, let me know!
