fusseli
- June 1, 2010
- 2002 4.6L
i am a first time exploder/mountaineer owner. gained interest from a friends old '96 4.0L Limited. just bought this mountaineer last monday, 2002 mountaineer (3rd gen, clearly) 4.6L AWD, seems loaded with all but sunroof and was very clean. 112k on it, paid $7200. http://yfrog.com/9gdownsizenjx
no glaring problems at all, have driven several hundred miles in the last week testing it out. there's an occasional hard shift somewhere between 2nd and 4th gear, has maybe happened twice though. the cruise control also seems to "hunt" for gears when going up steep grades, turning o/d off seems to help a bit. i hope the gear searching doesnt indicate it's slipping out of gear... other than that it shifts and rides pretty damn smooth, with all the power i'd expect.
AWD works well so far although i've noticed a single front wheel will spin and the other will not, when given a gnarly approach on an old 4x4 road. can't say for sure on the rears. i thought all these would have limited slip? from a take-off on a flat dirt road and accelerating through corners on dirt, the AWD works like a charm with no wheel spin and the gas pedal to the floor.
where can i check the build date? i have read around a bit on here and it seems like 02s had multiple known issues. anything i should do and/or look into soon? the dealer i bought it from turned the front rotors and changed the oil, nothing else. i'm considering taking it in to get the tranny and differential fluids changed.
thoughts and/or comments?
