smaidens
- January 17, 2008
- cambridge, ontario
- 2001 Sport 4WD
Hello, before I give my problems I just wanted to say that this site is amazing! I have read so much here already. You guys are great!
So here is my problem... I just recently bought a 01 Explorer sport 4WD 4.0 SOHC 160000Kms. The day after I brought it home the check engine light came on! I was going to crappy tire anyways so I had them pull the code for me. They told me it was P0174 - lean on bank 2. right away they said it needs a plenum gasket. I said I would get back to them cause I was not about to pay the $500 they quoted me for! So, I went to the d!ck... I mean dealer I bought it from and they said they could look at it but nothing would be covered under their warranty! So I am finished with them.
I found out from Ford that is had the 00M12 work done in 2004. Is it possible that it is leaking again on driver's side? I don't want to start chasing things that might not be the problem. I can't seem to feel, hear, see any vacuum leaks, I've cleaned the MAF, IAC, TB, change air filter etc, and yes it was extremely dirty! This really sucks because my dad is a mechanic for 35 years until he retired last year and moved out east, so he can't even look at it with me
Now, I don't know if crappy tire did any tests on it or just read in the book that this was one of the problems and thought here is a $500 job!
Other than this, it runs rough when it is -10 in the morning only for a few seconds, then it smooths out and stops rattling, runs fine other than the idle seems a bit low, around 500 - 600 rpm.
You guys are the experts, so what do you think?
