Before:
After:
The camera doesn't seem to take pictures of LEDs too well (except the night shots, looks below).
Justin146 sold me some LED panels already fabbed up with 8 - 10mm 10000 mcd hyper white LEDs that he imported in on each board (2). He did a very nice job on the work. Good quality stuff.
Anyway here is a picture of them
picture by justin146
Main thing for this set up is that LEDs are polarity set. LED (Light Emitting Diode); it is still a diode (which allows current to only flow in one way). So basically if you hook them up backwards you will think you got screwed over cause they won't light up. What I did was take my test light and found out which post was positive. After I figured that out I marked the side that was ground with a dot of white out. For these boards, the white wires were ground.
To get started you need to get the housings out. The screws are Torx bits so make sure you have a size 15 to get the screws out. After you have the housings out, basically "break" the clear cover off the black housing. This will give you access to where you can lay the LEDs in. They are just "jammed" in there, but that's the way it has to be so that they'll re-seal correctly.
I used clear silicone to reseal the housing. It looks nasty/messy (atleast for my likings - I'm a clean freak) -- but it gets the job done and it allows light to pass through it and hey, I had some left over from my rear differential cover install.
I am very happy with outcome of the project. But, the night time shots are the best. Take a look:
They are very nice. Very bright (like everyone always says, pictures can't do it justice). Thanks for the great stuff Justin!
Notes:
LED Puddle Light Project - by Justin146
-Drew
UPDATE 2-19-2006
Justin and I got together again and he shared with me some license plate and a map light LED board. I don't have any before shots, but you get the idea (the night pictures don't do it justice, they are BRIGHT!)
The Licesense Plate Board:
Justin's LED License Plate Project
they are very cool and bright!
After:
Notes:
-Drew
UPDATE 2-19-2006
