I decided to replace my instrument cluster illumination lamps with LEDs while I had the cluster out to fix my 5 x 5 chimes alert that the air bag lamp is nonfunctional. LEDs last longer and draw less current. I'm also considering replacing some of my status lamps with LEDs since its a pain to remove and install the instrument cluster. I know that the PCM monitors the air bag lamp since it detected it had failed (wasn't even installed). Since LEDs draw less current I'm concerned that if I replace status lamps monitored by the PCM it may detect them as failed. Does anyone know which status lamps can be replaced with LEDs without causing a detected failure?
