Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
I've been working on getting my engine (130k miles...God bless it ) prepped for a BBK S/C install sometime later this year. For about a year or so now, I've been hearing sounds in my engine that from what I understand is the infamous "lifter noise," (i.e.....some clattering on a cold start which goes away after the engine has warmed up). Using Gunk motor flush, Lucas oil stabilizer, and Purolator filters hasn't fixed the noise.....I'm not using/leaking oil either. So...I'm looking at replacing rocker arms, pushrods, and (maybe) lifters.
Questions:
When I do take off my valve covers to inspect my rocker arms and pushrods....am I correct in assuming that gaps between the rockers and valves = bad lifters? If I don't see any gaps....does it seem reasonable to assume that my lifters are still good (meaning that I just put in rocker arms and pushrods)? Or should I go ahead and replace the lifters as well to prevent any future problems?
Since Vanir seems to be out of the business of selling these parts on their site...suggestions on good places to get the parts?
Also...my Haynes manual states that the cam should be replaced when the lifters are replaced....is this necessary?
Thanks to all on this board who have helped me with other things before...advice on this matter would also be greatly appreciated.
-James
Questions:
-James
