calvinglen
- January 28, 2014
- Oklahoma City
- 1996 limited 4.0L V6
Hello everyone I have a few issues with my explorer and I was wondering if I could get some help.
I have a 1996 limited edition 4.0L 4wd V6 pearl(?) explorer.
The first and main problem is electrical related. When I turn on my lights the parking lights come on but nothing else. I can you my brights and that works just fine and it looks the same as when my lights use to work but the headlight casing itself is pretty gummed up from years of outdoor weather so my brights might just look like my headlights. If you have any idea let me know.
The second problem is the ac compressor, when I hit automatic or any other button besides vent on the temperature control panel the car shakes a bit and seems to lose a lot of power, I have since only used the vent button. I checked the pulley for the ac compressor and it still turns just fine so it's not locked up or anything. Any ideas please let me know.
The third issue I have is that the driver side window is extremely slow to roll down and it needs two or three clicks to actually come all the way down. I checked the connection in the door and it's all connected so it should work. I had the entire motor for the window replaced in the last 2 years as well. I'm kinda stuck on this one. Please help.
Last issue that is of concern. I had a blow out not too long ago and my driver side rear tire took of a bit of what I think is the running board or the rear quarter panel. Not the truck looks a bit odd with the wheel base showing. If you know what this piece is called or where to order one please let me know!
Thanks! I know this is a lot, the help is as always greatly appreciated
