- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Found an all metal shaft in a 97 sport at my favorite salvage yard. I pulled it my self, it was a little rusty and slightly bent, but I got it and the shaft that goes through the firewall and connects to the steering wheel for $10.
I pulled my stock steering shaft and the plastic was cracked, put it in a vice and put a little torque to it and there is the slack. I am going to go out and put in the junk yard part now.![]()
You might need to trim about 1/8" from the firewall end of new shaft-so it goes on far enough for th bolt hole to line up
also---tell me if your steering wheel is off about 1 /16 of a turn afterwards---
if so you adjust it at the tierods---just count the turns on each side--carefully to keep alignment correct.
try to avoid using all that stuff--thru firewall that is
good luck!!
