How to: Lower your explorer (pics)
albeegood
New Jersey
98 Explorer Sport 4x4
Thats odd. How fast are you taking those corners? What condition are your tires in?
Tires almost new. It started since putting shackle lift bars. It's kind of scary. That's why now I'm thinking on dropping my truck
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
cloud2or3
Burnaby, BC, Canada
97 Explorer Limited SOHC
Personally I dont think these trucks were meant to be lifted. Too narrow, then a high center of gravity...bad combination. Unless you widen the wheel base maybe. But what do I know lol.
albeegood
New Jersey
I agree & also it has a short wheelbase which is the reason it does that I think. I have a question. My truck has nice hight since I bought it 5.1/2" gap. I was wondering if twisting the torsion bars to high will it cause you to feel every little bump/hole/crack in the road?? I could be going around 15/20 mph and if I hit a 1" crack across the raid it's like I hit the biggest pot holes. Thx.
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
98 supercharged 347 sport
if your doing to drop a sport, the other thing you should do if you havent all ready is ditch the mono leafs in the back, and get a 4 door leaf pack. that there makes a world of a difference
albeegood
New Jersey
I
think you right. That's the reason I wanna lower it back down. I now have to take turns slow cause if I don't my rear sort of hops. I never touched my torsion bars when I brought my truck and it looks pretty nice and hight but I want to lower it, how much can I lower the front with just the torsion and is it true I have to realign it?? Thx.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Do you also need to replace the sway bar to do the drop?
I hope you still respond to this post. I have a 98 spot and I'm thinking on dropping it because on certain turns my trucks rear looses all traction and sort of hops around.
Upgrading the stock 19mm REAR sway bar may be your solution without lowering providing the tires and shocks are adequate and in safe condition. Also agree with vroom that ditching the stock mono leafs for 4-door multi leafs would make a big handling improvement. Must say a larger rear sway bar pretty much eliminated body roll and any traction issues when turning with my ST. Unfortunately the superb Explorer Express "X-Spec" rear sway bar is no longer available leaving the Hellwig 7648 or Addco 633 as your only options.
vroomzoomboom
selkirk, manitoba
i can truthfully say this. mines dropped 2 inches, has 245 60 20's and a EE sway bar. i have done clover leafs at 90kms (around 55mph).
albeegood
New Jersey
Thx. If that's the one in your profile photo it's nice. Now that we're on this subject I have another question. I have put just about all new in my front end from upper, lower a arms, ball joints, inner , outters, top, bottom, spindles, bearings, suspension bar links, new RS5000 RANCHO SHOCK and still I can feel every little bump, crack line as if i fall from two story high. You would think you hit a big ass hole when it would be just a 1" wide crack. My whole dash & console feels like it's gonna break right off. If there's one reason would want me to get rid off my truck that's it. Sorry for all the rambling. Any suggestions ??
B Lower explorer? Lowered Explorer - Ranger Suspension Tech 3
P Best way to lower my explorer?? Lowered Explorer - Ranger Suspension Tech 0
C i want to lower my 92 explorer with 20inch rims but idont want the front to butterfly Lowered Explorer - Ranger Suspension Tech 1
9 I want to lower my Explorer. Lowered Explorer - Ranger Suspension Tech 3
C Best way to lower a 2000 Explorer? Lowered Explorer - Ranger Suspension Tech 7
E looking to lower a 02 explorer sport Lowered Explorer - Ranger Suspension Tech 2
9 How do I lower my 1994 Eddie Bauer Explorer? Lowered Explorer - Ranger Suspension Tech 3
X Explorer lower on 22s. Lowered Explorer - Ranger Suspension Tech 19
I Trying to lower my 93 explorer eddie bauer Lowered Explorer - Ranger Suspension Tech 3
C Lower Explorer. Lowered Explorer - Ranger Suspension Tech 5
B How to lower my 2001 Explorer Sport 2dr Lowered Explorer - Ranger Suspension Tech 7
B Best way to lower my explorer Lowered Explorer - Ranger Suspension Tech 23
F how far will tt lower the explorer Lowered Explorer - Ranger Suspension Tech 17
S newbie asking questions to lower a 03 2wd Lowered Explorer - Ranger Suspension Tech 6
C Illusive Fabs upper and lower a arms Lowered Explorer - Ranger Suspension Tech 9
9 can u lower a 4x4? Lowered Explorer - Ranger Suspension Tech 5
B How Easy is it To lower a 2nd Gen 4x4 Lowered Explorer - Ranger Suspension Tech 2
Equnoxe Finnaly Decided To Lower My Truck. Few Questions. Lowered Explorer - Ranger Suspension Tech 6
Turdle Questions about going lower? Lowered Explorer - Ranger Suspension Tech 2
G Ok my X drives like a truck(horrible)--i would like to lower and handle better Lowered Explorer - Ranger Suspension Tech 9
I Going lower and fixing ball joint angles? Lowered Explorer - Ranger Suspension Tech 4
S Lower A arms, new product.. Lowered Explorer - Ranger Suspension Tech 26
A going to lower Lowered Explorer - Ranger Suspension Tech 3
B Removing leafs to lower? Lowered Explorer - Ranger Suspension Tech 14
RubySlow TT Lowered to max, How can I go lower? Lowered Explorer - Ranger Suspension Tech 2
S Lower Ball joints in Chassis Tech Drop I-beams.. Lowered Explorer - Ranger Suspension Tech 0
E New Torsion Keys to Lower Lowered Explorer - Ranger Suspension Tech 8
J anyone lower justr the front Lowered Explorer - Ranger Suspension Tech 3
C should I lower on all terrains. Lowered Explorer - Ranger Suspension Tech 3
F Want to go lower. want to know negitive effects. Lowered Explorer - Ranger Suspension Tech 21
C 2002 XLT - Can I lower with Blocks? Lowered Explorer - Ranger Suspension Tech 4
L help me lower my 01 sport Lowered Explorer - Ranger Suspension Tech 8
V cut lower control arms?? Lowered Explorer - Ranger Suspension Tech 1
S Need to find parts to lower my First GEN 2WD Lowered Explorer - Ranger Suspension Tech 3
L any lower? Lowered Explorer - Ranger Suspension Tech 2
Afboy143 Finally got the money to lower my truck, need some advice now Lowered Explorer - Ranger Suspension Tech 7
Afboy143 About to go lower my truck , need some advice Lowered Explorer - Ranger Suspension Tech 8
J Best way to lower a X Lowered Explorer - Ranger Suspension Tech 2
Afboy143 Cheapest way I found to lower the 99X, will it work? Lowered Explorer - Ranger Suspension Tech 9
A Lower the front for cheap Lowered Explorer - Ranger Suspension Tech 7
R Can I lower it? Lowered Explorer - Ranger Suspension Tech 3
A Pros and Cons to lower 01 ‘Sport Lowered Explorer - Ranger Suspension Tech 6
M LOWER/ RAISE SUSPENTION 2002 SPORT 4X2 Lowered Explorer - Ranger Suspension Tech 15
E Lowered w/1" blocks but left side is lower Lowered Explorer - Ranger Suspension Tech 6
R Lower My '03 Lowered Explorer - Ranger Suspension Tech 6
J who can lower a 2003 Aviator in CALI Lowered Explorer - Ranger Suspension Tech 30
T wanting to lower my sport trac, need help Lowered Explorer - Ranger Suspension Tech 11
B anyboby lower an awd 5.0? Lowered Explorer - Ranger Suspension Tech 14
J Lower Price For Edelbrock Shocks! Lowered Explorer - Ranger Suspension Tech 12
S NEED HELP WITH LOWER Lowered Explorer - Ranger Suspension Tech 2
Similar threads
