lowering kit for 91-94 explorer sport
jc_stang93
Gray, GA
92 Explorer Sport
does anyone know of a lowering kit for a 1992 explorer sport? i think eibach makes springs for the front but i cant find them. ive seen some 4x4 explorers with f150 springs on them. could i use f150 lowering springs? if so what modifications would i have to do? i was just thinking about using blocks for the rear. any suggestions would be greatly appreciated.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Hi
Welcome to the site--:D
I'm going to move this to the "sport truck" section, under the "seriously lowered suspensoin tech" forum
Anime
EF YEAH!!
2018 EX Sport Concept
Yes, Eibach makes 2" lowering springs for the front, which is what you want for a minor drop. For a real drop, you'll need "drop beams" which are cut beams to lower even more than just springs can do.
You can use blocks for the rear, but the correct way to do it is to have the leaf springs de-arched.
carter_55
st.petersburg, FL
1993 Explorer sport
could u send me a wed site for that 2" lowering kit that Eibach makes and were would i go to get the leaf springs de-arched ? How could i get some of these "drop beams" ?
fordfink87
94 ford explorer
I hear there are ranger springs that'll give you up to 4 inch's in the front.. ive had blocks on an s10, they were a little stiff but they worked. im currently trying to drop my 92 explorer sport. I'm not sure what year ranger the springs come from though
Anime
EF YEAH!!
The 92-97 2WD Ranger shares the Twin I-beam suspension with the 91-94 2WD Explorer, so drop springs for a Ranger fit, and should give slightly more drop because the Ranger is lighter and so the springs are softer, although some manufacturers did just use the same springs for both. Of course, drop springs for either are harder to find now than they were seven years ago when this thread was started.
Spdrcer34
Bremerton, WA
1992 Explorer XL
I have 5" of drop on my `92 X. 3" drop Beams, and 2" springs. Those parts are for sale if you want them. See the classified section.
