M5OD swap questions | Ford Explorer - Ford Ranger Forums - Serious Explorations
M5OD swap questions
limit_explore
Los Gatos, CA
'93 Limited
so my tranny is going on on my limited so i figured perfect time todo a swap.
so i know i need:
Clutch slave cylinder
clutch master cylinder
throw out bearing
clutch disk
pressure plate
flywheel
tranny
manual tranny ecu
pedal assembly
shifter
anything else? could i get the parts out of an 89 bronco 2 xlt? its a 2.9 though.
Glen4X4
Lewistown, Pa
2000 XLS
The 2.9 Trans will work, Foxracin has one in his Explorer.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
limit_explore
Los Gatos, CA
'93 Limited
yeah. ive got that bookmarked. read it everyday.
Tbars4
Moderator Emeritus
Elite In Memoriam
..Personally, I like steering them to threads I find either very useful or informative and I believe it's a big part of sharing the information on this Forum.. ..;)
..Hopefully the OP's will take the time to read these informative threads and find their answers there...
...If not, they can usually ask that thread writer (since they are experienced in that exact application in question) a question in their thread in case something was missed and all future readers can benefit from it...:biggthump
..:shifty_ey ...I'm heading back under my rock before I get into trouble..
limit_explore
Los Gatos, CA
'93 Limited
ok well thanks! im going to pick up a parts rig soon. so i can do my swap.
lifeguard379
sacremento,ca
93 eddie bauer 2 door
Need a new starter. Unless the b2 has a good one
limit_explore
Los Gatos, CA
'93 Limited
wait. that worries me.. can anyone give more details about that?
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Also make sure that your manual computer is 93 or 94 due to EGR being added in those years.
limit_explore
Los Gatos, CA
'93 Limited
doe the comp need to be from a expolrer? or can it be from a ranger, or bronco from 93-94
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
It needs to be setup for the 4.0, so a ranger or explorer OBD1 computer can be used.
limit_explore
Los Gatos, CA
'93 Limited
ok so if the b2 or ranger has a 4.0 itll work?
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
The b2 doesn't have egr, so it won't work.
Glen4X4
Lewistown, Pa
2000 XLS
Yeah, but BII's came with 2.9's unless it was swapped. EDIT: BII's no egr
limit_explore
Los Gatos, CA
'93 Limited
huh. ok well ill stick to looking for manual explorers and rangers then. anything else? what about that bearing?
wood1
North of Edmonton
'93 XLT, Cayman Green RIP
I would contact someone that would know for sure, I have never heard of a manufacturer doing that and would be surprised if it were true (no offense intended). Start a thread in the engine forum asking for anyone that has rebuilt an auto tranny Exploder engine... call Jasper engines, call a Ford dealer, if your tranny is shot and you aren't driving your truck pull the tranny now and look for yourself. Jack up your engine and remove the oil pan.
Wood.
snoranger
Jackson, NJ
94 limited on 35's
About 5-6 years ago i was looking to rebuild the 4.0l in my Ranger. Every rebuild kit I saw or asked about was listed as 2 options "manual or auto trans". No one could tell me the difference and the prices were the same. I guess this was the difference.
But I can tell you I did a few auto to manual swaps in 4.0l trucks. One of them went atleast 150k miles without any bearing problems.
